[mapguide-users] Mapguide Crashing IIS (w3wp.exe) service or viceVersa
Andrea Bell andrea_bell at comcast.net
Fri Jun 19 02:04:27 EDT 2009
We've seen his error with 3 different client applications.  All 3 are using
MGE 2009, not MGOS.  An official support case has been reported to Autodesk,
but so far no ideas on the cause or a resolution.
All 3 clients are running MGE 2009 with SP1 on Windows 2003, both w/SP1 &
SP2, all running IIS and .NET.
We believe it is related to the MGE 2009 service pack. At one client's the
error is fatal...requires not only a complete uninstall of MGE but also a
re-format of the drives and re-installation of the OS.  After re-installing
the OS, MGE 2009 w/SP1 still gives the same error.  However, format the
drives & re-install Win2003 and then install MGE 2009 WITHOUT SP1 resolves
the issue entirely on the same machine.  The second client can not afford to
take the server offline so we have a scheduled MGE service stop/start
process running every 15 mins.  At the 3rd client, the error occurs
periodically, but a simple reboot resolves it.
Again all of this occurs with MGE 2009, not MGOS, but figured for those of
you experiencing similar behavior this info might be of help.
Cheers,
Andrea
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andy Morsell
Sent: Wednesday, June 17, 2009 4:50 PM
To: 'MapGuide Users Mail List'
Subject: RE: [mapguide-users] Mapguide Crashing IIS (w3wp.exe) service or
viceVersa
I get a similar error message on Windows 2003 Server and MGOS 2.0.2.
Usually upon login in I'll have several console messages about w3wp.exe
error messages and sometimes the IIS Worker Process.  But, it's never been
fatal for me and MapGuide still ticks along (has been for about two months
without one restart) so I've ignored it for the most part.
I do have the raster patch described in this thread implemented, however.
Maybe that would help your problems.
http://n2.nabble.com/FDO-Gdal-raster-problem-tp2538452p2542802.html
Andy Morsell, P.E.
Spatial Integrators, Inc.
509-466-3959
www.SpatialGIS.com
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Tony
Sent: Wednesday, June 17, 2009 10:48 AM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Mapguide Crashing IIS (w3wp.exe) service or
vice Versa
Hi
i have the same issue with win2003 server sp2. and mge 2009
anyone has a clue. i thought my installation or server has issue so i got
fresh server and did new installation and the problem was there.  i think we
should have ticket for this issue ??
tony
Flipper wrote:
> Keep getting this error(See Below) on one specific machine on a regular
> basis...couldnt tell you whats different on this install from others...its
> Windows 2003 Server SP2...Anyone have any ideas?
> Application Errors:
> Event Type:     Error
> Event Source:   Application Error
> Event Category: (100)
> Event ID:       1000
> Date:           3/2/2009
> Time:           10:58:23 AM
> User:           N/A
> Computer:       SERVERNAME1
> Description:
> Faulting application w3wp.exe, version 6.0.3790.3959, faulting module
> isapi_MapAgent.dll, version 2.0.2.3402, fault address 0x00001cf4.
> For more information, see Help and Support Center at
> http://go.microsoft.com/fwlink/events.asp.
> Data:
> 0000: 41 70 70 6c 69 63 61 74   Applicat
> 0008: 69 6f 6e 20 46 61 69 6c   ion Fail
> 0010: 75 72 65 20 20 77 33 77   ure  w3w
> 0018: 70 2e 65 78 65 20 36 2e   p.exe 6.
> 0020: 30 2e 33 37 39 30 2e 33   0.3790.3
> 0028: 39 35 39 20 69 6e 20 69   959 in i
> 0030: 73 61 70 69 5f 4d 61 70   sapi_Map
> 0038: 41 67 65 6e 74 2e 64 6c   Agent.dl
> 0040: 6c 20 32 2e 30 2e 32 2e   l 2.0.2.
> 0048: 33 34 30 32 20 61 74 20   3402 at
> 0050: 6f 66 66 73 65 74 20 30   offset 0
> 0058: 30 30 30 31 63 66 34      0001cf4
> Event Type:     Error
> Event ID:       1000
> Date:           3/2/2009
> Time:           10:58:20 AM
> User:           N/A
> Description:
> Data:
> Event Type:     Error
> Event ID:       1000
> Date:           3/2/2009
> Time:           10:58:17 AM
> User:           N/A
> Description:
> Data:
> Event Type:     Error
> Event ID:       1000
> Date:           3/2/2009
> Time:           10:58:14 AM
> User:           N/A
> Description:
> Data:
> Event Type:     Error
> Event ID:       1000
> Date:           3/2/2009
> Time:           10:58:08 AM
> User:           N/A
> Description:
> Data:
> System Errors:
> Event Type:     Warning
> Event Source:   W3SVC
> Event Category: None
> Event ID:       1011
> Date:           3/2/2009
> Time:           10:58:10 AM
> User:           N/A
> Description:
> A process serving application pool 'MapGuide' suffered a fatal
> communication error with the World Wide Web Publishing Service. The
> process id was '4140'. The data field contains the error number.
> Data:
> 0000: 6d 00 07 80               m..?
> Event Type:     Warning
> Event Source:   W3SVC
> Event ID:       1009
> Date:           3/2/2009
> Time:           10:58:14 AM
> User:           N/A
> Description:
> A process serving application pool 'MapGuide' terminated unexpectedly. The
> process id was '2264'. The process exit code was '0xc0000005'.
> Event Type:     Warning
> Event Source:   W3SVC
> Event ID:       1011
> Date:           3/2/2009
> Time:           10:58:17 AM
> User:           N/A
> Description:
> process id was '6328'. The data field contains the error number.
> Data:
> Event Type:     Warning
> Event Source:   W3SVC
> Event ID:       1011
> Date:           3/2/2009
> Time:           10:58:20 AM
> User:           N/A
> Description:
> process id was '2988'. The data field contains the error number.
> Data:
> Event Type:     Warning
> Event Source:   W3SVC
> Event ID:       1011
> Date:           3/2/2009
> Time:           10:58:24 AM
> User:           N/A
> Description:
> process id was '6244'. The data field contains the error number.
> Data:
> Event Type:     Error
> Event Source:   W3SVC
> Event ID:       1002
> Date:           3/2/2009
> Time:           10:58:24 AM
> User:           N/A
> Description:
> Application pool 'MapGuide' is being automatically disabled due to a
> series of failures in the process(es) serving that application pool.
View this message in context:
http://n2.nabble.com/Mapguide-Crashing-IIS-%28w3wp.exe%29-service-or-vice-Ve
rsa-tp2411452p3094352.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
No virus found in this incoming message.
Checked by AVG - www.avg.com
Version: 8.5.339 / Virus Database: 270.12.76/2183 - Release Date: 06/17/09
05:53:00
