[mapguide-users] Can you write to a database when a feature is selected?
JamesDudden jamesdudden at blueyonder.co.uk
Fri Jun 19 04:32:24 EDT 2009
Thanks for the reply Kenneth, your way is probably right but I figured it out
another way:
I passed a variable (feature ID) to my asp page using the URL activated for
feature section. I then picked up the variable and wrote it in to my
database. Simple:)
Kenneth Skovhede, GEOGRAF A/S wrote:
> Yes, you would issue something like:
> INSERT INTO TABLE (ID) VALUES (?)
> And then pass in the selected feature ID.
> Was that what you meant?
> Regards, Kenneth Skovhede, GEOGRAF A/S
View this message in context: http://n2.nabble.com/Can-you-write-to-a-database-when-a-feature-is-selected--tp3113389p3118434.html
