[mapguide-users] creating package problem
padmini godavarthi godavarthi.padmini at gmail.com
Mon Jun 29 07:06:41 EDT 2009
Hi kenneth,
after creating package i just pressed "Show In Browser" button in layout
template
i got the map like
http://n2.nabble.com/file/n3173735/template.jpeg
i got an error msg in the log file................................
Regards,
Padmini.
Kenneth Skovhede, GEOGRAF A/S wrote:
> You should get an error message when you
> start the viewer also.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> padmini godavarthi skrev:
>> Hi,
>> when i clicked on this map i got the error msg that
>>     "<2009-06-29T15:36:01> 			Administrator
>>  Error: Invalid argument(s):
>>         The value cannot be less than or equal to zero.
>>  StackTrace:
>>   - MgRenderingServiceHandler.ProcessOperation line 83 file
>> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\rendering\RenderingServiceHandler.cpp
>>   - MgOpQueryFeatures.Execute line 125 file
>> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\rendering\OpQueryFeatures.cpp
>>   - MgServerRenderingService.QueryFeatures line 652 file
>> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\rendering\ServerRenderingService.cpp
>>   - MgServerRenderingService.RenderForSelection line 1041 file
>> The value cannot be less than or equal to zero."
>> Regards,
>> Padmini G.
>>> What are the messages in the error log file?
>>>>   Hi,
>>>> iam using mapguide opensource 2.0 (with .net 2.0 +IIS 5.1).
>>>> and iam using mapguide maestro for creating packages.
>>>> it works fine (loading package on ajax viewer).
>>>> suddenly i got a problem from the last 2 days.the map is not showing on
>>>> the
>>>> browser.......
>>>> http://n2.nabble.com/file/n3173532/template.jpeg
>>>> i didn't get the problem.................
>>>> why it happens???????????///
>>>> can anybody helps me in this situation...........?
>>>> Regards,
>>>> Padmini G.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/creating-package-problem-tp3173532p3173735.html
