[mapguide-users] UpdateFeatures
Zac Spitzer zac.spitzer at gmail.com
Tue Mar 3 02:43:44 EST 2009
cool, can you file a new bug? it should be raising an exception!
z
2009/3/3 Ivan Milicevic <Ivan.Milicevic at supranet.hr>:
> Zac,
> I have found error. Sdf file was marked as READ ONLY. Now, everything works perfectly. Thank's a lot for your time.
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
> - Show quoted text -
> Sent: Monday, March 02, 2009 12:26 PM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] UpdateFeatures
> it's gonna take some one who knows C++ and the mapguide
> code base to do this..
> out of interest which provider where you using?
> this should raise an exception right?
> 2009/3/2 Ivan Milicevic <Ivan.Milicevic at supranet.hr>:
>> So, I'll wait till 2.1 release.
>> Thanks a lot, I've spend a whole weekend to solve it but without exception or error code it's impossible.
>> Thank's again.
>> Sent: Monday, March 02, 2009 12:07 PM
>> hmm, these are both quite critical bugs IMHO...
>> we are talking about potential dataloss here,
>> should be a blocker for 2.1, I've updated the ticket for be high
>> http://trac.osgeo.org/mapguide/ticket/649
>> z
>>> Strange, i can get GetValue() but i can get name and it's "0".
>>> .GetItem(0).Name is "0"
>>> and
>>> GetItem(0).GetPropertyType() is "9"
>>> Sent: Monday, March 02, 2009 11:49 AM
>>> same as result.GetItem(0).GetPropertyType() ?
>>> z
>>>> Value is 9
>>>> Sent: Monday, March 02, 2009 11:46 AM
>>>> what is the value of  result.GetItem(0).GetValue() ?
>>>> On Mon, Mar 2, 2009 at 4:46 PM, Ivan Milicevic
>>>> <Ivan.Milicevic at supranet.hr> wrote:
>>>>> Hello Zac, hello group
>>>>> I'm havig the same problems as George has. Tried
>>>>> result.GetItem(0).GetValue() and resoult is 9. Can you help me? I'm
>>>>> really suffering to create this "easy to do" feature.
>>>>> The following code does it well, no execption, no errors but no deleted
>>>>> feature as well.
>>>>> PLease, be note that Filter string is fine.
>>>>> Thanx a lot.
>>>>>        string TIMgisUser =
>>>>> System.Configuration.ConfigurationManager.AppSettings["TIMgisUser"];
>>>>>        MapGuideApi.MgInitializeWebTier(@"C:\program
>>>>> files\MapguideOpenSource2.0\WebServerExtensions\www\webconfig.ini");
>>>>>        MgUserInformation userInfo = new
>>>>> MgUserInformation("Administrator", "" +
>>>>> System.Configuration.ConfigurationManager.AppSettings["mgP"] + "");
>>>>>        MgSite site = new MgSite();
>>>>>        site.Open(userInfo);
>>>>>        String mgSessionId = site.CreateSession();
>>>>>        MgUserInformation userInfoNew = new
>>>>> MgUserInformation(mgSessionId);
>>>>>        MgSiteConnection siteConnection = new MgSiteConnection();
>>>>>        siteConnection.Open(userInfoNew);
>>>>>        MgResourceService resourceService =
>>>>> siteConnection.CreateService(MgServiceType.ResourceService) as
>>>>> MgResourceService;
>>>>>        MgFeatureService featureService =
>>>>> siteConnection.CreateService(MgServiceType.FeatureService) as
>>>>> MgFeatureService;
>>>>>        MgResourceIdentifier resId = new
>>>>> MgResourceIdentifier("Library://PROJEKTI/ZLZ/PODACI/DIONICE.FeatureSourc
>>>>> e");
>>>>>        MgFeatureCommandCollection commands = new
>>>>> MgFeatureCommandCollection();
>>>>>        MgDeleteFeatures deleteCmd = new MgDeleteFeatures("DIONICE",
>>>>> "(FeatId='1')");
>>>>>        commands.Add(deleteCmd);
>>>>>        featureService.UpdateFeatures(resId, commands, false);
>>>>>        string re = featureService.UpdateFeatures(resId, commands,
>>>>> false).GetItem(0).GetPropertyType().ToString();
>>>>>        Response.Write(featureService.TestConnection(resId));
>>>>> Sent: Friday, August 01, 2008 3:06 AM
>>>>> Subject: Re: [mapguide-users] MG 1.2 vs 2.0.1
>>>>> yep...it does fail silently, which is really annoying.. it should just
>>>>> raise an exception
>>>>> On Fri, Aug 1, 2008 at 4:16 AM, George McLean <gmclean at gorge.net> wrote:
>>>>>> No I am not. Does this ignore the error message and process the update
>>>>>> somehow?
>>>>>> Zac Spitzer wrote:
>>>>>>> Are you checking the result as bellow
>>>>>>> result=featureService.UpdateFeatures(resourceID, fCommand, false);
>>>>>>> if (result.GetItem(0).GetPropertyType() eq 9)
>>>>>>>    result.GetItem(0).GetValue() // Silent FDO error messages!!!!
>>>>>>> z
>>>>>>> On Fri, Aug 1, 2008 at 2:14 AM, Zac Spitzer <zac.spitzer at gmail.com>
>>>>> wrote:
>>>>>>>> can you post some code to demonstrate the problem?
>>>>>>>> On Fri, Aug 1, 2008 at 2:05 AM, George McLean <gmclean at gorge.net>
>>>>> wrote:
>>>>>>>>> Hello,
>>>>>>>>> I am a bit stuck in upgrading to 2.0.1 mainly due to the issues
>>>>> with
>>>>>>>>> adding
>>>>>>>>> data to feature sources discussed in this thread:
>>>>> http://www.nabble.com/Please-try-your-operation-later-as-the-resource-wa
>>>>> s-busy-to16392736.html#a18556960
>>>>>>>>> My immediate issue is that I have a client that would really like
>>>>> to us
>>>>>>>>> FF
>>>>>>>>> 3.0 with my application. I see that either I need to find a way to
>>>>> apply
>>>>>>>>> the
>>>>>>>>> fixes made in 2.0 for FF to 1.2 or find a way around the issues
>>>>> with
>>>>>>>>> updating feature data.
>>>>>>>>> I could look at the code for MG 1.2 and apply the changes made to
>>>>> 2.0
>>>>>>>>> with
>>>>>>>>> some guidance on where to start but I think I would rather find a
>>>>> fix
>>>>>>>>> for MG
>>>>>>>>> 2.0.
>>>>>>>>> Any suggestions would be appreciated.
>>>>>>>>> Thanks
>>>>>>>>> George McLean
>>>>> _______________________________________________
>>>>> mapguide-users mailing list
>>>>> mapguide-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>> Zac Spitzer -
>>>> http://zacster.blogspot.com
>>>> +61 405 847 168
>>> Zac Spitzer -
>>> +61 405 847 168
>> Zac Spitzer -
>> +61 405 847 168
> Zac Spitzer -
> +61 405 847 168
Zac Spitzer -
+61 405 847 168
