[mapguide-users] Regarding - Set Feature Label at Run Time
ravinder.singh at BIRLASOFT.COM ravinder.singh at BIRLASOFT.COM
Wed Mar 4 06:39:39 EST 2009
Hi All,
I have to set a property as Feature Label for a layer at run time. I got
some hints and tried with VectorLayerDefinitionType and
TextSymbolType.But not able to do so as I don't know the exact
procedure.
I am using maestro api for creating run time map.
Please assist...
I am using c#, asp.net.
Thanks & Regards,
Ravinder
*********************************************************************************************************************************************************************%CRLF%"This message and any attachments are solely for the intended recipient and may contain Birlasoft confidential or privileged information. If you are not the intended recipient,any disclosure,copying, use, or distribution of the information included in this message and any attachments is %CRLF%prohibited. If you have received this communication in error, please notify us by reply e-mail at (administrator at birlasoft.com) and permanently delete this message and any attachments. Thank you."%CRLF%*********************************************************************************************************************************************************************%CRLF%
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090304/d574996c/attachment.html
