[mapguide-users] Help for a newbie :)
Michael G. Byrne MByrne at tonkin.co.nz
Wed Mar 4 15:46:35 EST 2009
Does the sample download have a package now? It only used to have the data in directories (e.g. as after loading a package) that could be copied to the mapguide site.
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of ravinder.singh at BIRLASOFT.COM
Sent: Wednesday, 4 March 2009 4:24 a.m.
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] Help for a newbie :)
Every thing is fine except you don't have Sheboygan.mgp, so you download
it from the map guide site and just copy and paste this into C:\Program
Files\MapGuideOpenSource2.0\Server\Packages folder.
Then when you click on Manage Packages in server admin ,you will find
the Package  there this time. Now you have to click on Load Package Link
just above in the header of grid. It will take some time to upload the
package.
Thanks & Regards,
Ravinder
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of ashaman
Sent: Tuesday, March 03, 2009 8:44 PM
Subject: [mapguide-users] Help for a newbie :)
Hello all,
I'm investigting the use of mapguide open source for my company, i'm an
I.T.
analist, and I'm having an issue with the initial setup.
>From the getting started guide, I can do the following steps without
issue:
1. Download and install the MapGuide Server and MapGuide Web Server
Extensions.
2. Download and extract the sample application.
3. Download the sample data.
But at step 4 something falls appart. Here's the verbage for step 4:
4. Load the sample data using the Site Administrator application.
Open a web browser to the following URL:
http://localhost:8008/mapguide/mapadmin/login.php.
Login using the user id "Administrator" and the default password
"admin".
When you see the
Manage Servers page appear, select "Load Packages" in the left
navigation
bar. Select the radio
button next to Sheboygan.mgp and click "Load Package".
I can log into the site, no problems there. But I don't see Load
Packages in
the left navigation bar. What I do see is Manage Packages. I click that,
and
I do see Load Packages at the bottom of the page, but I don't see
Sheboygan.mgp in the list, the list is actually blank. At the top of the
page is  'Make Package', but I can't seem to get that to work either. I
don't know what to type in for the folder name.
In directory C:\Program Files\MapGuideOpenSource2.0\Server\Packages I
have
myresourcepackagemanifest.xml
there also exists sub directory :C:\Program
Files\MapGuideOpenSource2.0\Server\Packages\Library\Samples\Sheboygan
but I don't actually see an .mgp file anywhere
Thanks in advance!
Marc
View this message in context:
http://n2.nabble.com/Help-for-a-newbie-%3A%29-tp2415739p2415739.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
*********************************************************************************************************************************************************************%CRLF%"This message and any attachments are solely for the intended recipient and may contain Birlasoft confidential or privileged information. If you are not the intended recipient,any disclosure,copying, use, or distribution of the information included in this message and any attachments is %CRLF%prohibited. If you have received this communication in error, please notify us by reply e-mail at (administrator at birlasoft.com) and permanently delete this message and any attachments. Thank you."%CRLF%*********************************************************************************************************************************************************************%CRLF%
Tonkin & Taylor: Celebrating 50 years in 2009.
http://www.tonkin.co.nz
This email is only intended to be read by the named recipient. It may contain information that is confidential, proprietary or the subject of legal privilege. If you are not the intended recipient please notify the sender immediately and delete this email. You may not use any information contained in it. Legal privilege is not waived because you have read this email.
