[mapguide-users] Create programmatically a map
sekko970 sekko970 at virgilio.it
Thu Mar 5 07:55:32 EST 2009
Hi Kenneth,
I solved the problem. I write you the solution, in the hope that it can be
useful.
The error is generated because in my XML template were missing the nodes
<PrintLayout>
    <ResourceId></ResourceId>
</PrintLayout>
as childs of <Command xsi:type="PrintCommandType"> node, even if these nodes
are not generated from MGMaestro saving a new WebLayout as XML, and the
PrintLayout element is descripted as optional (minOccurs="0") in
WebLayout-1.0.0.xsd schema file.
Thanks for your help.
Fabio
sekko970 wrote:
> This is the result of posting:
>   <?xml version="1.0" encoding="UTF-8" ?>
> - <ResourceList xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xsi:noNamespaceSchemaLocation="ResourceList-1.0.0.xsd">
> - <ResourceDocument>
>   <ResourceId>Library://MyApp/AppLayouts/MyLayout.WebLayout</ResourceId>
>   <Depth>3</Depth>
>   <Owner>Administrator</Owner>
>   <CreatedDate>2009-03-04T15:50:26Z</CreatedDate>
>   <ModifiedDate>2009-03-04T17:02:27Z</ModifiedDate>
> - <ResourceDocumentHeader
> xsi:noNamespaceSchemaLocation="ResourceDocumentHeader-1.0.0.xsd">
> - <Security xsi:noNamespaceSchemaLocation="ResourceSecurity-1.0.0.xsd">
>   <Inherited>true</Inherited>
> - <Groups>
> - <Group>
>   <Name>Everyone</Name>
>   <Permissions>r,w</Permissions>
>   </Group>
>   </Groups>
>   </Security>
>   </ResourceDocumentHeader>
>   </ResourceDocument>
>   </ResourceList>
> I also found that the error is originated if the XML has nodes like
> <Function>Command</Function>; if the XML has nodes like
> <Function>Separator</Function>, there aren't errors.
> Fabio
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> Have you tried posting the document to the webform?
>> http://localhost/mapguide/mapagent/index.html
>> Regards, Kenneth Skovhede, GEOGRAF A/S
>> sekko970 skrev:
>>> Dear all,
>>> I just found the cause of my problem.
>>> My web-layout xml template is a copy of a new layout XML structure
>>> created
>>> from MGMaestro:
>>> <?xml version="1.0" encoding="utf-8"?>
>>> <WebLayout xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>>> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
>>> xsi:noNamespaceSchemaLocation="WebLayout-1.0.0.xsd">
>>> 	<Title>MyMapTitle</Title>
>>> 	<Map>
>>> 		<ResourceId>MyMap.MapDefinition</ResourceId>
>>> 		<HyperlinkTarget>TaskPane</HyperlinkTarget>
>>> 	</Map>
>>> 	<ToolBar>
>>> 		<Visible>true</Visible>
>>> 		<Button xsi:type="CommandItemType">
>>> 			<Command>Print</Command>
>>> 		</Button>
>>> 	</ToolBar>
>>> 	<InformationPane>
>>> 		<Width>200</Width>
>>> 		<LegendVisible>true</LegendVisible>
>>> 		<PropertiesVisible>true</PropertiesVisible>
>>> 	</InformationPane>
>>> 	<ContextMenu>
>>> 		<MenuItem xsi:type="CommandItemType">
>>> 			<Command>Select</Command>
>>> 		</MenuItem>
>>> 	</ContextMenu>
>>> 	<TaskPane>
>>> 		<Width>280</Width>
>>> 		<TaskBar>
>>> 			<Home>
>>> 				<Name>Home</Name>
>>> 				<Tooltip>Return to home task page</Tooltip>
>>> 				<Description>Return to home task page</Description>
>>> 				<ImageURL>../stdicons/icon_home.gif</ImageURL>
>>> <DisabledImageURL>../stdicons/icon_home_disabled.gif</DisabledImageURL>
>>> 			</Home>
>>> 			<Forward>
>>> 				<Name>Forward</Name>
>>> 				<Tooltip>Forward to next task page</Tooltip>
>>> 				<Description>Forward to next task page</Description>
>>> 				<ImageURL>../stdicons/icon_forward.gif</ImageURL>
>>> <DisabledImageURL>../stdicons/icon_forward_disabled.gif</DisabledImageURL>
>>> 			</Forward>
>>> 			<Back>
>>> 				<Name>Back</Name>
>>> 				<Tooltip>Return to previous task page</Tooltip>
>>> 				<Description>Return to previous task page</Description>
>>> 				<ImageURL>../stdicons/icon_back.gif</ImageURL>
>>> <DisabledImageURL>../stdicons/icon_back_disabled.gif</DisabledImageURL>
>>> 			</Back>
>>> 			<Tasks>
>>> 				<Name>Tasks</Name>
>>> 				<Tooltip>Task list</Tooltip>
>>> 				<Description>View a list of available tasks</Description>
>>> 				<ImageURL>../stdicons/icon_tasks.gif</ImageURL>
>>> <DisabledImageURL>../stdicons/icon_tasks_disabled.gif</DisabledImageURL>
>>> 			</Tasks>
>>> 			<MenuButton xsi:type="CommandItemType">
>>> 				<Command>Measure</Command>
>>> 			</MenuButton>
>>> 		</TaskBar>
>>> 	</TaskPane>
>>> 	<StatusBar>
>>> 	</StatusBar>
>>> 	<ZoomControl>
>>> 	</ZoomControl>
>>> 	<CommandSet>
>>> 		<Command xsi:type="BasicCommandType">
>>> 			<Name>Pan</Name>
>>> 			<Label>Pan</Label>
>>> 			<Tooltip>Pan mode</Tooltip>
>>> 			<Description>Drag the map to view areas out of range</Description>
>>> 			<ImageURL>../stdicons/icon_pan.gif</ImageURL>
>>> <DisabledImageURL>../stdicons/icon_pan_disabled.gif</DisabledImageURL>
>>> 			<TargetViewer>All</TargetViewer>
>>> 			<Action>Pan</Action>
>>> 		</Command>
>>> 	</CommandSet>
>>> </WebLayout>
>>> If the XML layout definition contains a <button> node chilld of
>>> <toolbar>
>>> node, or a <MenuItem> node chilld of <ContextMenu> node, or a
>>> <MenuButton>
>>> chilld of <TaskPane><TaskBar> node, or a <Command> node chilld of
>>> <CommandSet> node, it is generated the following error:
>>> The type 'OSGeo.MapGuide.MgNullArgumentException' nell'assembly
>>> 'MapGuideDotNetApi, Version = 2.0.2.3011, Culture = neutral,
>>> PublicKeyToken
>>> = null' is not marked as serializable.
>>> How can I fix it?
>>> Thanks in advance.
>>> Fabio
>>>> There are/were problems reading data using the MgByteReader, as it
>>>> would
>>>> not return more than 8K.
>>>> You are using the native API, which, IMO, has some quirks.
>>>> Maestro uses the http interface to store the file, so that is
>>>> equivalent
>>>> to posting using the webform.
>>>> sekko970 skrev:
>>>>> The file is 21K.
>>>>> I tryed also to load it directly from Maestro, and I have had no
>>>>> problem.
>>>>>> Just to be sure...
>>>>>> The xml you posted is the ResourceHeader, and not the
>>>>>> ResourceContent,
>>>>>> so it does not really show what the problem may be.
>>>>>> The error from the log states that the runtime map is not created,
>>>>>> which
>>>>>> is strange because a WebLayout cannot reference a runtime map.
>>>>>> The other error you posted seemed to indicate that the Print command
>>>>>> was
>>>>>> invalid inside the WebLayout.
>>>>>> Can you try so save the xml, just before you write it to the
>>>>>> MgByteStream?
>>>>>> Then try to post the file, using the SetResource in the webform
>>>>>> mentioned earlier.
>>>>>> If you get the same error, try to post the file somewhere, and
>>>>>> provide a
>>>>>> link.
>>>>>> Be carefull not to copy/paste, but post the actual file.
>>>>>> Btw. how large is the file? larger than 8K?
>>>>>> _______________________________________________
>>>>>> mapguide-users mailing list
>>>>>> mapguide-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/Create-programmatically-a-map-tp2314238p2429177.html
