[mapguide-users] [SOLUTIONATED]Polygon are not recorded in feature
Micho Gar michogar at gmail.com
Thu Mar 5 14:02:05 EST 2009
After much testing, I created a shp with a ESRI's tool, and she has worked.
Before, I was creating the shp with gvSIG, and it seems that there is a
problem in some way not understood with MapGuide.
Thanks to all.
2009/3/4 Micho Gar <michogar at gmail.com>
> Thanks to all,
> this the XML for this resource
> <FeatureSource xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
> <Provider>OSGeo.SHP</Provider>
> <Parameter>
> <Name>DefaultFileLocation</Name>
> <Value>%MG_DATA_PATH_ALIAS[datos]%poligonos/zonas.shp</Value>
> </Parameter>
> <Parameter>
> <Name>TemporaryFileLocation</Name>
> <Value>%MG_DATA_PATH_ALIAS[datos]%temp/</Value>
> </Parameter>
> </FeatureSource>
> I am still looking for that these days I could not get it.
> 2009/3/3 Ivan Milicevic <Ivan.Milicevic at supranet.hr>
>>  MIcho,
>> Please, open http://gis.supranet.hr/mapguide/mapagent/index.html click on
>> Resource->GetResourceContent
>> Maybe your feature source is set to rtead only. I had the same problem in
>> past couple of days.
>> *From:* mapguide-users-bounces at lists.osgeo.org [mailto:
>> mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Micho Gar
>> *Sent:* Monday, March 02, 2009 6:44 PM
>> *To:* MapGuide Users Mail List
>> *Subject:* [mapguide-users] Polygon are not recorded in feature
>> Hi all,
>> I have a code that should save the polygons in the feature source after
>> using the Digitize. In principle I do not give any error, but when reviewing
>> the shp the polygon don´t appear. I leave with you the code because I don´t
>> see anything bad.
>> MgUserInformation userInfo = new MgUserInformation(sessionId);
>> MgSiteConnection siteConnection = new MgSiteConnection();
>> siteConnection.Open(userInfo);
>> MgResourceService resourceService =
>> (MgResourceService)siteConnection.CreateService(MgServiceType.ResourceService);
>> MgFeatureService featureService =
>> (MgFeatureService)siteConnection.CreateService(MgServiceType.FeatureService);
>> MgResourceIdentifier zonasFeatureId = new
>> MgResourceIdentifier("Library://ConectorGPS/Datos/poligonosZonas.FeatureSource");
>> MgFeatureCommandCollection zonasComando = new
>> MgFeatureCommandCollection();
>> //Abrimos el mapa
>> MgMap mapa = new MgMap();
>> mapa.Open(resourceService, mapName);
>> //creamos la geometria
>> MgGeometryFactory geometryFactory = new MgGeometryFactory();
>> MgCoordinateCollection coordinateCollection = new
>> MgCoordinateCollection();
>> //MgLinearRingCollection interiorRingCollection = new
>> MgLinearRingCollection();
>> MgAgfReaderWriter geometryReaderWriter = new MgAgfReaderWriter();
>> int count = xCollection.length;
>> for(int i=0; i<count;i++)
>>     Double x = Double.valueOf(xCollection[i]);
>>     Double y = Double.valueOf(yCollection[i]);
>>     MgCoordinate  coordinate = geometryFactory.CreateCoordinateXY(x,y);
>>     coordinateCollection.Add(coordinate);
>> MgLinearRing exteriorRing =
>> geometryFactory.CreateLinearRing(coordinateCollection);
>> MgPolygon polygon = geometryFactory.CreatePolygon(exteriorRing,null);
>> MgByteReader geom = geometryReaderWriter.Write(polygon);
>> //creamos una coleccion de propiedades y la insertamos
>> MgPropertyCollection propiedades = new MgPropertyCollection();
>> propiedades.Add(new MgGeometryProperty("Geometry", geom));
>> propiedades.Add(new MgStringProperty("ID", "zona1"));
>> zonasComando.Add(new MgInsertFeatures("zonasCapa", propiedades));
>> featureService.UpdateFeatures(zonasFeatureId, zonasComando, false);
>> //capturamos la capa para salvar el mapa y refrescar
>> MgLayerBase zonasCapa = mapa.GetLayers().GetItem("zonasCapa");
>> zonasCapa.SetVisible(true);
>> zonasCapa.ForceRefresh();
>> mapa.Save(resourceService);
>> out.println("finish");
>> Thanks
>> # michogar
>> # Analista Programador SIG
>> # Ubuntu Linux Counter 462666
>> "Cuenta una leyenda que si reproduces un DVD de Windows Vista original al
>> revés se oye a Bill Gates entonando cantos satánicos... Pero eso no es lo
>> peor... Si lo reproduces del derecho... ¡Se instala!."
>> "It has a legend that if you play an original Windows Vista DVD backwards
>> to hear Bill Gates Satanic chanting songs ... But that's not the worst ...
>> If you play it right ... It installs!.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> # michogar
# michogar
"It has a legend that if you play an original Windows Vista DVD backwards to
hear Bill Gates Satanic chanting songs ... But that's not the worst ... If
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090305/2759b22c/attachment.html
