[mapguide-users] Base64 encoding decoding scenarios
Warren Medernach wmedernach at rand.com
Fri Mar 6 16:27:19 EST 2009
Ah ha!, thanks so much Traian, that explains it better.
I think you've kicked me onto the right path!
Thanks again.
Warren
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Traian
Stanev
Sent: Friday, March 06, 2009 1:09 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Base64 encoding decoding scenarios
You have to know the data type of the thing you are decoding. If it is a
string, the decoded byte array is a utf8 string with a null terminator.
So you have to look at it as an array of bytes, and not a number.
If I take the integer 892744497 and convert to hex using little endian,
I get the bytes { 0x31, 0x33, 0x36, 0x35 }. If I look at this as an
array of characters, it corresponds to { '1', '3', '6', '5'}.  Does that
look familiar?
Traian
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Warren
Medermach (External)
Sent: Friday, March 06, 2009 1:58 PM
No ideas, comments, suggestions from anyone?  ;-)
Warren M
Medernach
Sent: Monday, March 02, 2009 10:43 AM
Subject: [mapguide-users] Base64 encoding decoding scenarios
I'm working on decoding the UIDs passed in the selection XML, and I want
to thank the group for all of the posts on decoding base 64 as I can
successfully decode a UID now!
However, when I attempt to decode a UID that is NOT made up a single
integer field, I'm running into some problems:
Scenario #1:
If the UID consists of 2 integer fields, upon decoding, only the first
value is returned.
Example, objects Key fields are:
     UID1: value=1684
     UID2: value=1365
When I decode this, only the first value, 1684, is returned.
Do I need to do something different for decoding a feature where there
are multiple key fields?
Scenario #2
If the UID consists of a text field, the decoded value is incorrect.
Example, object UID = '1365-1684'
Decoded, the returned value is: 892744497
And I noticed if multiple objects are selected, it seems all of the
decoded values are: 892744497
Any comments, ideas, suggestions would be greatly appreciated.
Warren M
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090306/05de5c39/attachment.html
