[mapguide-users] Modify layout and layer on map
euskalmap ziburudebian at free.fr
Tue Mar 10 04:09:24 EDT 2009
Hi Kenneth
Thanks a lot for your information; I'm trying to use Maestro API
Regards
Kenneth Skovhede, GEOGRAF A/S wrote:
> Take a look at this page, it shows how to modify the map before it loads:
> http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI/samples/AddInitialLayer
> I think it's pretty close to what you want.
> It is using the MaestroAPI, which is a bit different from the official
> API, but the general idea is the same.
> On this page you can see how to modify the layer filter, after the map
> has loaded:
> http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI/samples/ModifyLayerFilter
> General documentation for the MaestroAPI is here:
> Regards, Kenneth Skovhede, GEOGRAF A/S
> euskalmap skrev:
>> Hi, sorry for my late reply !! So, i do not understand where can i
>> writing my code (remember that my code change layout definition and
>> filters in map layers). mapgudie load map in
>> /mapguide/mapvierwernet/ajaxviewer.aspx,
>> /mapguide/mapvierwernet/mainframe.aspx and
>> /mapguide/mapvierwernet/mapframe.aspx. If I execute the code before
>> /mapguide/mapvierwernet/ajaxviewer.aspx (like
>> ajaxtiledviewersample.aspx in dotnetviewersample), nothing append :
>> the original map and filter with no modify are loading! If I execute
>> after, I do not where ?? you say '/simply provide the end user with a
>> link to your special page.In that page, do the setup, and then
>> redirect to the MapGuide viewer files (Response.Redirect). '/ in my
>> special page i call /mapguide/mapvierwernet/ajaxviewer.aspx but who do
>> I execute the instruction Response.Redirect ? Tanks Francis
>> ____________________________________________________
>>     If you are modifying the layout, you probably want to run your
>>     code before starting the application. To do so, simply provide the
>>     end user with a link to your special page. In that page, do the
>>     setup, and then redirect to the MapGuide viewer files
>>     (Response.Redirect). If you want to modify the map, while running
>>     the viewer, you can either setup a handler for the maps "OnLoad",
>>     which trigger your special page, or you can put in pages through
>>     "Custom Actions" on the layout. Regards, Kenneth Skovhede, GEOGRAF
>>     A/S euskalmap skrev: > hi, > I developed a program which modify
>>     layout and layer on the map. > I do not who can i call this
>>     program (it is an aspx file with C# code) : > > in a file in the
>>     directory mapguide/mapviewernet and with a #include or > after the
>>     last instruction who lad the map in a mapguide file ? > I don't no
>>     who ? > > I will not modify mapguide file to avoid the errors at
>>     the time of new the > version mapguide. > > Have you an idea ? >
>>     _______________________________________________ mapguide-users
>>     mailing list mapguide-users at lists.osgeo.org
>>     http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> View this message in context: Re: Modify layout and layer on map
>> <http://n2.nabble.com/Modify-layout-and-layer-on-map-tp2268226p2450009.html>
>> Sent from the MapGuide Users mailing list archive
>> <http://n2.nabble.com/MapGuide-Users-f1803227.html> at Nabble.com.
>> mapguide-users mailing list
View this message in context: http://n2.nabble.com/Modify-layout-and-layer-on-map-tp2268226p2453776.html
