[mapguide-users] Modify mapdefinition in a layout
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Wed Mar 11 17:41:10 EDT 2009
You need to create the UTF8Encoding object with the parameter "false"
(meaning disable BOM).
A slightly easier way to do this:
http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI/samples/CustomizedZoomWithWebLayout
Regards, Kenneth Skovhede, GEOGRAF A/S
euskalmap skrev:
> Hi
> I provide the end user with a link to my special page (see the code1). In
> that page i redirect to the MapGuide viewer files (Response.Redirect).
> code1:
> http://n2.nabble.com/file/n2462320/sample1.jpg
> The fonction SetLayout Map modify the mapdefinition in my layout. See image
> here :
> http://n2.nabble.com/file/n2462320/sample2.jpg
> The problem : the layout is not modify and i have this message : An
> exception occurred in the XML parser.
> Have you an idea ?
> Thanks
