[mapguide-users] Modify mapdefinition in a layout
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Thu Mar 12 08:23:34 EDT 2009
It is very trivial to convert the sample to C#... in fact I just did:
http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI/samples/CustomizedZoomWithWebLayout
If you just want to understand what happens, there should be a more
verbose message in the error.log:
C:\Program Files\MapGuideOpenSource2.0\Server\logs\error.log
Also, are you certain that the pst_map is a valid map identifier, and
that str_NewMapDefinition is a valid resource identifier?
I'm guessing that pst_map is a string like:
"Library://map.MapDefinition", so your str_NewMapDefinition becomes:
Session:<sessionid>//Library://map.MapDefinition.MapDefinition
Regards, Kenneth Skovhede, GEOGRAF A/S
euskalmap skrev:
> Hi,
> It do not run with the parameter false in the instruction UTF8Encoding utf8
> = new UTF8Encoding(false);
> In your link sample(
> ), it is a vb code with the mapguide maetro api; i will not change all my
> code because i use c# with mapguide api; i want to undestand why it do not
> run; i use the same method to change the filter in layers and it run very
> well ! what's append in my code?
> thanks
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> You need to create the UTF8Encoding object with the parameter "false"
>> (meaning disable BOM).
>> A slightly easier way to do this:
>> euskalmap skrev:
>>> Hi
>>> I provide the end user with a link to my special page (see the code1). In
>>> that page i redirect to the MapGuide viewer files (Response.Redirect).
>>> code1:
>>> http://n2.nabble.com/file/n2462320/sample1.jpg
>>> The fonction SetLayout Map modify the mapdefinition in my layout. See
>>> image
>>> here :
>>> http://n2.nabble.com/file/n2462320/sample2.jpg
>>> The problem : the layout is not modify and i have this message : An
>>> exception occurred in the XML parser.
>>> Have you an idea ?
>>> Thanks
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090312/e1f91343/attachment.html
