[mapguide-users] SQL 2008 Geographic data type can't be selected
Martin Morrison martin.morrison at edsi.com
Fri Mar 13 12:13:43 EDT 2009
Maybe I am misunderstanding what the issue is.  Early on you stated:
" for the case of geographic data type the
selection of the features is not possible."
So what exactly is the issue that you are having?
Martin
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Rodolfo Moreno
Sent: Friday, March 13, 2009 11:18 AM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] SQL 2008 Geographic data type can't be selected
That's right. geometry type in sql 2008 is working correctly. It means you
can display and select the features.
Martin Morrison wrote:
> I just want to note that I am using SQL 2008 to display geometry without
> any issues...
> Martin
> Moreno
> Sent: Friday, March 13, 2009 10:55 AM
> selected
> Hi all,
> I was reviewing others theards with relation to it.
> http://n2.nabble.com/Layer%27s-selection-Problem-td2352146.html
> It seems to be an issue with geography data type in sql 2008. I would like
> to post a ticket but I don't know exactly in where is the error in
> mapguide
> or FDO.
> Any opinion?
> Regards
> Rodolfo Moreno wrote:
>> Yes, my table has primary key (as integer) and spatial index with
>> geographic grid.
>> Regards,
>> Dave Wilson wrote:
>>> Can you ensure your table has a primary key? I'm pretty sure it's
>>> required.
>>> Dave
>>> Moreno
>>> Sent: Friday, March 06, 2009 4:01 PM
>>> selected
>>> Hi Andrei,
>>> sorry for my delay.
>>> I have created a new sql table with geography sql type and I added two
>>> simple polygons.
>>> here is my sql script:
>>> insert into test1
>>> VALUES (1,geography::STGeomFromText('POLYGON ((0 0 ,1 0,1 1 , 0 1, 0 0
>>> 4326) )
>>> insert into test1
>>> VALUES (2,geography::STGeomFromText('POLYGON ((1 1 ,3 1,2 3 , 1 1 ))',
>>> 4326)
>>> Next I have displayed the features with the ajax viewer of the MGOS (I
>>> am
>>> using 2.0.1 version) and the result is the same.
>>> It means that the features are shown but these can't be selected.
>>> I guess that it is an issue of MGOS. have you ever had success with it?
>>> Regards,
>>>> Thanks Andrei, I am goin to try your suggestion.
>>>> miansi wrote:
>>>>> Hello Rodolfo,
>>>>> Make sure you set SRID while populating SQL:
>>>>> , [Geo] = GEOMETRY::STGeomFromText([import].[Geo], @SRID)
>>>>> Base on your map (WGS 84) your SRID should be something like 4326
>>>>> Regards,
>>>>> Andrei
>>>>> Moreno
>>>>> Sent: Monday, March 02, 2009 9:15 AM
>>>>> Subject: [mapguide-users] SQL 2008 Geographic data type can't be
>>>>> selected
>>>>> I have could select features from geometric data type (sql 2008 as
>>>>> data
>>>>> source) however, for the case of geographic data type the selection of
>>>>> the
>>>>> The error shown in the log is: "sys.geometry is incompatible with
>>>>> sys.geography"
>>>>> The map that contains this layer is set as WGS 84.
>>>>> any help will be appreciated, thanks
>>>>> Rodolfo Moreno
>>>>> CivilEng
>>>>> View this message in context:
>>>>> http://n2.nabble.com/SQL-2008-Geographic-data-type-can%27t-be-selected-t
>>>>> p2410036p2410036.html
>>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>>> _______________________________________________
>>>>> mapguide-users mailing list
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>>> ----Notice Regarding Confidentiality----
>>>>> This email, including any and all attachments, (this "Email") is
>>>>> intended
>>>>> only for the party to whom it is addressed and may contain information
>>>>> that is confidential or privileged.  Sierra Systems Group Inc. and its
>>>>> affiliates accept no responsibility for any loss or damage suffered by
>>>>> any person resulting from any unauthorized use of or reliance upon
>>>>> this
>>>>> Email.  If you are not the intended recipient, you are hereby notified
>>>>> that any dissemination, copying or other use of this Email is
>>>>> prohibited.
>>>>> Please notify us of the error in communication by return email and
>>>>> destroy all copies of this Email.  Thank you.
>>> Rodolfo Moreno
>>> CivilEng
>>> http://n2.nabble.com/SQL-2008-Geographic-data-type-can%27t-be-selected-tp2410036p2438599.html
> Rodolfo Moreno
> CivilEng
> http://n2.nabble.com/SQL-2008-Geographic-data-type-can%27t-be-selected-tp2410036p2473836.html
Rodolfo Moreno
CivilEng
View this message in context: http://n2.nabble.com/SQL-2008-Geographic-data-type-can%27t-be-selected-tp2410036p2473971.html
