[mapguide-users] Layer's selection Problem
miansi AndreiSinelnikov at SierraSystems.com
Mon Mar 16 14:08:07 EDT 2009
Hello,
Sorry for late responce.
Everything should work. You have to check few things:
1. You have to have UNIQUE NON CLUSTERED INDEX on PointID column
2. You have to have Spatial INDEX on Point column
3. Map also have to use SRID 4326 (WGS 84)
4. Check on the Map that layer marked as selectable - it is not by default
It should work,
Andrei
aniliht wrote:
> I'm also using a sql server 2008 and have 2 simple tables as follows:
> Drawing
> - DrawingID (PK, int, not null)
> - DrawingName (varchar(50))
> Point
> - PointID (PK, int, not null)
> - DrawingID (FK, int, not null)
> - Name (varchar(50))
> - Point (geography, not null)
> There is one row in each table,  the geography instance is in SRID 4326
> (WGS 84).  The item displays properly but I can't select it no matter
> what.
> I'm using the windows install of Mapguide 2.0.2:
> MgServerSetup-2.0.2.3011.exe.  It did not have the SQL Server Spatial
> provider bundled.  So I installed the
> fdosqlserverspatial-3.3.0_win32.tar.gz which is SQL Server Spatial BETA 1.
> I chose this because the dll version of the bundled FDO.dll that the
> MgServerSetup installed was 3.3.0.3901.
> Do you know if the BETA 1 version of the SQL Server Spatial provider
> doesn't support selection on layers?
> What version of MapGuide, FDO, SQL Server Spatial Provider releases work
> to be able to select points on a SQL layer?
> Is it ok to install the latest version of FDO (which is 3.3.2) into the
> C:\Program Files\MapGuideOpenSource2.0\Server\Bin\FDO directory,
> overwritting the contents that the MgServerSetup placed?
> The release notes for MG 2.0.2 says: "MGOS 2.0.2 is compatible with FDO
> 3.3.1 but the version packaged with the installers is actually a newer
> version."  But the version of FDO in the Bin directory appears to be
> 3.3.0.3901.
> Thanks for any clues you can provide.
> miansi wrote:
>> I have exactly the same behaviour for SQL 2008.
>> I do not know if this is applicable for Oracle, but for SQL
>> 1. You have to have Primary Key (clustered) on the table you want to show
>> on the layer
>> 2. PK has to be int
>> 3. You have to create spatial index on the spatial column
>> 4. As soon as you will try to add JOINS to your database view (if you
>> trying to show layer off View) - you will lose selection functionality. I
>> am fighting with this one for week already.
>> Hope that will help
>> padmini godavarthi wrote:
>>> Hi,
>>> iam using mapguide opensource 2.0 (with .net 2.0 +IIS 5.1)
>>> I have created a package using Oracle "OSGEO FDO provider for Oracle"
>>> and Mapguide Maestro.
>>> but while seeing the map by"Show in browser" the layers are does not
>>> selecting on map and the properties is not displaying even after i
>>> checked the option "Features on layer are selectable" in the map
>>> resource.
>>> Is anything i did wrong?
>>> Can u plz tell me the solution?
>>> Thanks and Regards,
>>> Padmini.
View this message in context: http://n2.nabble.com/Layer%27s-selection-Problem-tp2352146p2487575.html
