[mapguide-users] Modify mapdefinition in a layout
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Tue Mar 17 09:54:46 EDT 2009
Is this a question?
The un-edited file loads fine for me.
Regards, Kenneth Skovhede, GEOGRAF A/S
euskalmap skrev:
> Hi,
> I have not send the good link of my file; in the previous version , i have
> trying to delete in the xml the string
> "xsi:noNamespaceSchemaLocation="WebLayout-1.0.0.xsd".
> So, my file is :  http://patxi.mayol.free.fr/Untitled1.xml
> So i test GetResourceContent rather than SetResource :
> If i try  http://localhost/mapguide/mapagent/index.html
> http://localhost/mapguide/mapagent/index.html  with GetResourceContent on
> "Library://Ag Base/Mpg Urbanisme.WebLayout" and submit, i have this result :
> http://n2.nabble.com/file/n2490672/test.jpg
> The message in header, in french, is in english : This file XML does not
> seem to have of information of style associated with him. The tree of the
> document is shown below.
> SO
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> A bit tricky, something to do with how .Net handles Xml I think.
>> The document is missing the attribute:
>> Which is required, because it is used for versioning and validation.
>> If you take your document and open this page:
>> Then click "Resource" -> "SetResource", point out the file,
>> and in the "ResourceID" field type: "Library://mytest.WebLayout".
>> Then set the "Content" field to point to the file and click submit.
>> You will see the error you mention.
>> Now add the above attribute, so the second line in the document becomes:
>> <WebLayout xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
>> xsi:noNamespaceSchemaLocation="WebLayout-1.0.0.xsd">
>> Save the document, click back in the browser, and then "Submit" once more.
>> This time it works. (Remember to check that the ResourceID and Content
>> field has not been reset).
>> euskalmap skrev:
>>> Hi,
>>> Yes, i have see the log file, but there is no more information that 'XML
>>> Parser error'.
>>> The logfile is :
>>> http://n2.nabble.com/file/n2474100/logfile.jpg
>>> About the XML file, after modification i have this file :
>>> http://patxi.mayol.free.fr/mytest.xml
>>> Thanks
>>> regards
>>>> Did you look in the error.log file?
>>>> Could you try to save the xml document after modification, and send a
>>>> link to it?
>>>> euskalmap skrev:
>>>>> Hi,
>>>>> In fact, before modification, i have
>>>>> MgResourceIdentifier webLayoutId = new
>>>>> MgResourceIdentifier(pst_weblayout)
>>>>> with pst_weblayout = "Library://Ag Base/MyLayout.WebLayout"
>>>>> I search the xml node for modify Mapdefinition resource and
>>>>> after modification i have in instruction
>>>>> webLayoutId = new MgResourceIdentifier(str_NewMapDefinition)
>>>>> with str_NewMapDefinition=Session:xxxxxxxxx//MyMap.MapDefinition
>>>>> So, i set the resource and i have the message 'An exception occurred in
>>>>> the
>>>>> XML parser.'
>>>>> I say it is simply to migrate vb to c#, but before i want to
>>>>> understand.
>>>>> I have use same sample who use this method on the forum; but i do not
>>>>> explain where is my bug?
>>>>> thanks a lot for your help
>>>>>> It is very trivial to convert the sample to C#... in fact I just did:
>>>>>> http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI/samples/CustomizedZoomWithWebLayout
>>>>>> If you just want to understand what happens, there should be a more
>>>>>> verbose message in the error.log:
>>>>>> C:\Program Files\MapGuideOpenSource2.0\Server\logs\error.log
>>>>>> Also, are you certain that the pst_map is a valid map identifier, and
>>>>>> that str_NewMapDefinition is a valid resource identifier?
>>>>>> I'm guessing that pst_map is a string like:
>>>>>> "Library://map.MapDefinition", so your str_NewMapDefinition becomes:
>>>>>> Session:<sessionid>//Library://map.MapDefinition.MapDefinition
>>>>>> euskalmap skrev:
>>>>>>> Hi,
>>>>>>> It do not run with the parameter false in the instruction
>>>>>>> UTF8Encoding
>>>>>>> utf8
>>>>>>> = new UTF8Encoding(false);
>>>>>>> In your link sample(
>>>>>>> ), it is a vb code with the mapguide maetro api; i will not change
>>>>>>> all
>>>>>>> my
>>>>>>> code because i use c# with mapguide api; i want to undestand why it
>>>>>>> do
>>>>>>> not
>>>>>>> run; i use the same method to change the filter in layers and it run
>>>>>>> very
>>>>>>> well ! what's append in my code?
>>>>>>> thanks
>>>>>>>> You need to create the UTF8Encoding object with the parameter
>>>>>>>> "false"
>>>>>>>> (meaning disable BOM).
>>>>>>>> A slightly easier way to do this:
>>>>>>>> euskalmap skrev:
>>>>>>>>> Hi
>>>>>>>>> I provide the end user with a link to my special page (see the
>>>>>>>>> code1).
>>>>>>>>> In
>>>>>>>>> that page i redirect to the MapGuide viewer files
>>>>>>>>> (Response.Redirect).
>>>>>>>>> code1:
>>>>>>>>> http://n2.nabble.com/file/n2462320/sample1.jpg
>>>>>>>>> The fonction SetLayout Map modify the mapdefinition in my layout.
>>>>>>>>> See
>>>>>>>>> image
>>>>>>>>> here :
>>>>>>>>> http://n2.nabble.com/file/n2462320/sample2.jpg
>>>>>>>>> The problem : the layout is not modify and i have this message : An
>>>>>>>>> exception occurred in the XML parser.
>>>>>>>>> Have you an idea ?
>>>>>>>>> Thanks
>>>>>>>> _______________________________________________
>>>>>>>> mapguide-users mailing list
>>>>>>>> mapguide-users at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090317/89683553/attachment.html
