[mapguide-users] CompositeTypeStyle conflicting with AreaTypeStyle
manafi jonathan.manafi at cctechnol.com
Tue Mar 17 14:41:49 EDT 2009
I'm having trouble including composite symbol definitions with line/area
styles at the same scale range in a LayerDefinition. The symbolization
aspect works just fine, as they show up properly in the map. But, whenever I
have a composite style defined for a scale, if there are any line and/or
area styles also defined, they disappear from the map but show up in the
legend. If I zoom out to a scale range with no composites defined, I see the
line and area styles just fine.
I tested this with data from an sdf file, as well as from King.Oracle.
Does anyone else see results like this? Is the composite definition not
meant to be used in conjunction with line or area styles?
This is in MGOS 2.0.2, WinXP, apache
View this message in context: http://n2.nabble.com/CompositeTypeStyle-conflicting-with-AreaTypeStyle-tp2493094p2493094.html
