[mapguide-users] SQL datastore and Point Features
Jamo adam.jamison at portbris.com.au
Tue Mar 17 20:58:42 EDT 2009
I am trying to display point features that are stored in Lat/Long in a sql
database in my current map being GDA94 / Zone 56, This data is reprojected
in the correct position (a single point is all that is available at the
moment for testing so 1 point displays in the correct position) and
displayed in the correct position.
The problem I'm encountering is when I try to select the point feature ...
it does not seem to be selectable... however If I create a map in it's
native coordinate system I can then select the feature..... Is this a bug?
View this message in context: http://n2.nabble.com/SQL-datastore-and-Point-Features-tp2494796p2494796.html
