[mapguide-users] Unable to connect to MGOS via MapGuide Studio/.NET API
Rui Daniro ruidaniro at hotmail.co.uk
Wed Mar 18 05:54:51 EDT 2009
I already tried to restart both and still the same.
Rui
De: prbabu (via Nabble) [mailto:ml-user+140549-171910985 at n2.nabble.com]
Enviada: 17 March 2009 23:22
Para: Rui Daniro
Assunto: RE: [mapguide-users] Unable to connect to MGOS via MapGuide
Studio/.NET API
Sometimes, both the web server and the MapGuide service needs to be
restarted to get things back to normal.
-Praveen
From: Rui Daniro (via Nabble) [mailto:ml-user+165274-1835885226 at ...
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2494445&i=0> ]
Sent: Tuesday, 17 March 2009 10:57 PM
To: Praveen Rajendra Babu
Subject: Re: [mapguide-users] Unable to connect to MGOS via MapGuide
Studio/.NET API
Hi all,
I am having the same problem, I left the MGOS server (version 2.0.2.3011)
idle for a while(like overnight) and then try to connect to server via
Maestro, I get the sames messages, the only difference is that I am using
apache instead IIS. I tried to restart apache and nothing changed.
prbabu wrote:
I am not sure either. What I did is not allow the worker process to recycle
within IIS, even when idle and also created a separate application pool for
mapguide itself. This morning, I am able to login/see the map without any
re-starts. Would not conclude this as the solution yet - needs more
investigation.
Thanks for your response, though.
Regards,
Praveen
Kenneth Skovhede, GEOGRAF A/S wrote:
That look really odd.
What happens is that Maestro connects to
http://localhost/mapguide
but this is really mapped to
http://localhost/mapguide/mapagent/mapagent.fcgi
There is some logic inside Maestro (line 1027 in HttpServerConnection.cs),
that maps from the short form to the long form.
If the short form fails, the long form is attempted.
If the long form fails, the exception for the short for is thrown,
which is likely what happens here.
I have no idea why an IIS restart would fix connection problems with
MapGuide.
Regards, Kenneth Skovhede, GEOGRAF A/S
Praveen Rajendra Babu skrev:
> Hi,
>     If I leave the MGOS server (version 2.0.2.3011) idle for a
> while(like overnight) and then try to connect to server via Maestro, I
> get the message.
> ************************* Maestro pop-up window message
> Maestro
> Failed to log on because: Failed to connect, please check network
> connection and login information.
> Extended error info: Failed to connect, perhaps session is expired?
> Extended error info: Invalid server token recieved: <html><head><META
> http-equiv="Content-Type" content="text/html;
> charset=UTF-8"><title>osenlighten -
> /mapguide/</title></head><body><H1>osenlighten - /mapguide/</H1><hr>
> <pre>[To Parent Directory]<br><br>    Monday, December
> 22, 2008  3:25 PM        <dir>  HREF="/mapguide/data/">data<br>    Monday,
December 22, 2008  3:32
> PM        <dir>
HREF="/mapguide/dotnetviewersample/">dotnetviewersample<br>
> Tuesday, January 20, 2009 12:02 PM        <dir>
HREF="/mapguide/fusion/">fusion<br>    Tuesday, January 20, 2009
> 11:54 AM      1847872
HREF="/mapguide/fusion-1.1.0.zip">fusion-1.1.0.zip<br>   Thursday,
> January 08, 2009  9:46 AM        <dir>
HREF="/mapguide/fusion-old/">fusion-old<br>    Monday, December
> 22, 2008  3:25 PM        <dir>  HREF="/mapguide/localized/">localized<br>
Monday, December 22,
> 2008  3:25 PM        <dir>  HREF="/mapguide/mapadmin/">mapadmin<br>
> 2008  3:25 PM        <dir>  HREF="/mapguide/mapagent/">mapagent<br>
Wednesday, January 21,
> 2009  6:08 PM        <dir>
HREF="/mapguide/mapviewernet/">mapviewernet<br>   Tuesday,
> December 23, 2008 12:24 PM        <dir>
HREF="/mapguide/mapviewerphp/">mapviewerphp<br>    Monday,
> December 22, 2008  3:25 PM        <dir>  HREF="/mapguide/nad/">nad<br>
Friday, January 30, 2009  2:31
> PM        <dir>  HREF="/mapguide/OpenLayers-2.7/">OpenLayers-2.7<br>
Friday,
> January 30, 2009  1:52 PM        <dir>
HREF="/mapguide/phpviewersample/">phpviewersample<br>    Monday,
HREF="/mapguide/schemareport/">schemareport<br>    Monday,
HREF="/mapguide/stdicons/">stdicons<br>    Monday, December 22,
> 2008  3:25 PM        <dir>  HREF="/mapguide/viewerfiles/">viewerfiles<br>
Monday, December
> 22, 2008  3:27 PM         8245
HREF="/mapguide/webconfig.ini">webconfig.ini<br>    Monday,
HREF="/mapguide/webstudio/">webstudio<br></pre><hr></body></html>
> OK
> If I try to connect to the MGOS server via .NET API code, I get the
> below message:
> <html>
> <head>
> <title>MgConnectionFailedException</title>
> <meta http-equiv="Content-type" content="text/html; charset=utf-8">
> </head>
> <body>
> <h2>Cannot establish connection.</h2>
> Exception occurred in method MgServerConnection.Open at line 106 in
> file
d:\buildforgeprojects\carrera_nightly\build_32.2\ent\os\common\mapguidecommo
n\Services/ServerConnection.cpp
> </body>
> </html>
>    To get things back to normal, I re-start WWW services in Windows
> Server 2003. Am I missing something in the set-up or configuration of
> MGOS or IIS Server?  FYKI, we are using IIS Server v6.0.
> Any comments/suggestions would be highly appreciated.
> Thanks and regards,
> Praveen
> mapguide-users mailing list
> mapguide-users at ...
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2494445&i=1>
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2494445&i=2>
  _____
This email is a reply to your post @
http://n2.nabble.com/Unable-to-connect-to-MGOS-via-MapGuide-Studio-.NET-API-
tp2476671p2490925.html
You can reply by email or by visting the link above.
  _____
tp2476671p2494445.html
No virus found in this incoming message.
Checked by AVG - www.avg.com
Version: 8.0.238 / Virus Database: 270.11.18/2009 - Release Date: 03/18/09
07:17:00
View this message in context: http://n2.nabble.com/Unable-to-connect-to-MGOS-via-MapGuide-Studio-.NET-API-tp2476671p2496215.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090318/de4f76bc/attachment.html
