[mapguide-users] re: mapguide integration with google maps
Chris Claydon chris.claydon at autodesk.com
Tue Mar 24 16:58:56 EDT 2009
OpenLayers supports both Google and MapGuide layers, so it is reasonably easy to build OpenLayers applications that display both. Check out http://openlayers.org for more details. Last time I did a search for this, I found a sample PHP script that performed the necessary MapGuide layer initialization.
I believe Fusion 2.0 also supports Google layers, so it should be possible to combine MG and Google in a flexible layout.
The one 'trick' that I found if you want your MG map to align properly with Google (or Virtual Earth or Yahoo) is to assign it a spherical Mercator coordinate system. If you do a search, you should be able to find the WKT definition of such a coordinate system, and drop it into your map definition XML.
Chris.
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of girish kumar bv
Sent: Tuesday, March 24, 2009 12:04 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] re: mapguide integration with google maps
Hi all,
is there api for mapguide integration with google maps.Any help is appreciated.
regards,
girish
[http://sigads.rediff.com/RealMedia/ads/adstream_nx.ads/www.rediffmail.com/signatureline.htm@Middle]<http://sigads.rediff.com/RealMedia/ads/click_nx.ads/www.rediffmail.com/signatureline.htm@Middle?>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090324/8a8ee076/attachment.html
