[mapguide-users] Modify mapdefinition in a layout
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Fri Mar 27 04:06:21 EDT 2009
Not sure why, but both of those files have the UTF-8 BOM header :(.
Regards, Kenneth Skovhede, GEOGRAF A/S
euskalmap skrev:
> Hi,
> Yes, the browser can read the xml file : i have generate 2 files : one just after reading the doc ( http://patxi.mayol.free.fr/test_before.xml ) and another one after modify the Map id ( http://patxi.mayol.free.fr/test_after.xml ) : the 2 files an be reading in my browser .
> You can see my code here : http://patxi.mayol.free.fr/sample3.asp
> regards
> Even if you don't have any xsd files in c:\temp, you should be able to
> open the xml document using Internet Explorer (just drag it into it).
> Have you tried to not change the xml, and just save it back to MapGuide
> after reading it?
> (In your code, just comment out the part that writes the new Map id into
> the xml.)
> euskalmap skrev:
>> HI,
>> Yes i have the file WebLayout-1.0.0.xsd in the directory C:\Program Files\MapGuideOpenSource2.0\Server\Schema\.
>> which method you want that I use to save the weblayout ?
>> If i save the weblayout in my code with the instruction ,
>> FileStream fs = File.Create("c:\\temp\\test.xml");
>> fs.Write(encodedBytes, 0, encodedBytes.Length);
>> it is normal that i can not read the weblayout because the file WebLayout-1.0.0.xsd is not present in c:\temp directory.
>> I have not understand how saving and reading the weblayout ?
>> Other question : Perhaps my mapguide server is not correctly parameterized?
>> Thanks for your lelp.
>> Yes, it is very strange that it happens with only weblayouts.
>> Do you have the file:
>> C:\Program Files\MapGuideOpenSource2.0\Server\Schema\WebLayout-1.0.0.xsd
>> Can you save the weblayout if you just read it, and then save it? (eg.
>> not changing anything).
>> euskalmap skrev:
>>> Hi,
>>> I have try your maestro class in my sample like this :
>>> http://patxi.mayol.free.fr/sample2.asp
>>> I have always the same error.
>>> In the mapguide log file it say 'An exception occurred in the XML parser.'
>>> and at the end i say about an error in
>>> MgResourceContentManager.ValidateDocument.
>>> Perhaps, Mapguide server can not find the WebLayout.1.0.0.xsd file ?
>>> What you think about it?.
>>> NB:It is very strange that there is no problem with filter in layer and as
>>> much problem to modify mapdefinition in layout !!!
>>> Thanks
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090327/d469bffe/attachment.html
