[mapguide-users] Using the MapAgent directly to create map images.
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Mon Mar 30 10:27:55 EDT 2009
You should use "GETMAPIMAGE".
If you use GETDYNAMICOVERLAYERIMAGE, you will not see any tiled layers
(layers in base layer groups).
Regards, Kenneth Skovhede, GEOGRAF A/S
TravisBrannon skrev:
> Hi folks,
> Can someone out there please tell me when using the MapAgent directly (as I am developing my own viewer) when should I use GETMAPIMAGE and GETDYNAMICMAPOVERLAYIMAGE?  Is there a conceptual difference here?  And if so, please explain what that difference is?  I notice that the Ajax Viewer seems to consistently use the GETDYNAMICMAPOVERLAYIMAGE method?  Yet I am having issues with it.
> Any help would be appreciated.
> Thanks,
> Travis
