[mapguide-users] can anyone solved this buffer problem
padmini godavarthi godavarthi.padmini at gmail.com
Fri May 1 00:08:08 EDT 2009
Thanks for ur  reply
1)can u plz tell me how to retrieve features with in the buffer
area(actually im a little bit confused)
Regards,
Padmini.
Kenneth Skovhede, GEOGRAF A/S wrote:
> It looks correct, it seems to follow the edges as expected.
> When creating the buffer, a simple method is to take each line, and
> buffer it,
> so it gets rounded corners.
> Then alle the resulting buffer items are combined into a single object
> that is the buffer.
> If I look at your image, that seems to happen correctly.
> The long side at the bottom right seems to be reflected in the buffer
> edge.
> If you would like it to be a perfect circle, you should only buffer a
> point,
> not a polygon.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> padmini godavarthi skrev:
>> Hi Kenneth,
>>   i have created a buffer with 0.2 miles but i think the buffer is not
>> creating accurately
>>      http://n2.nabble.com/file/n2745746/buffer.jpeg
>> 1) can u provide any solution?????????????
>> 2)And can u plz tell me the code for retrieving parcel_id with in the
>> buffer
>> area(im a little bit confused)
>> plzzzzzzzz
>> Regards,
>> Padmini.
>>> It looks correct to me. Try using a smaller buffer to better determine
>>> accuracy.
>>> For the second question, you have already asked that in another thread.
>>> The AJAX viewer shows selection data, so try looking at the
>>> selection.aspx files,
>>> and see how it works.
>>>> Hi  Kenneth,
>>>> Thanku very much for ur help.............
>>>> i did the coordinate system override as per ur instructions.
>>>> It works fine
>>>> but i felt that the buffer feature is not coming accurately??
>>>> what was the problem????????????????????????????
>>>> i mean by observing closely  its not an accurate circle(buffer layer).
>>>> http://n2.nabble.com/file/n2683455/pic.jpeg
>>>> 2)secondly i want to retrieve the parcel_ids that are included or
>>>> intersected in the buffer layer.How  is it possible ? can u send me the
>>>> sample code?????????
>>>> Thanks in advance.
>>>> Regards,
>>>> Padmini.
>>>>> Thats because the Sheboygan data uses a true georeferenced coordinate
>>>>> system,
>>>>> and your data is using a non-georeferenced system, like XY-M.
>>>>> Arbitrary should be understood as "non-georeferenced".
>>>>> If your data is not in the same projection as the map, you cannot use
>>>>> the buffer feature.
>>>>> This then returns to my initial statement: "Coordinate System
>>>>> Override",
>>>>> which can
>>>>> set the data coordinate system to match the maps.
>>>>> Can you please report what happened with with the suggestions I made,
>>>>> regarding the coordinate system overrides?
>>>>>> Hi,
>>>>>> In my data
>>>>>>     bool arbitraryMapSrs = (srsMap.GetType() ==
>>>>>> MgCoordinateSystemType.Arbitrary);
>>>>>> arbitraryMapSrs comes as true but in sheboygan data it comes as false
>>>>>>         if (arbitraryMapSrs)
>>>>>>             mapSrsUnits = srsMap.GetUnits();
>>>>>> In mydata mapSrsUnits comes as "meter" but in sheboygan data it comes
>>>>>> as
>>>>>> null
>>>>>> so that
>>>>>>  if ((arbitraryDsSrs != arbitraryMapSrs) || (arbitraryDsSrs &&
>>>>>> (dsSrsUnits
>>>>>> != mapSrsUnits)))
>>>>>>                 excludedLayers++;
>>>>>>                 continue;
>>>>>> In my data  excludedLayers comes as 1 and where as in sheboyan data
>>>>>> this
>>>>>> condition fails....................
>>>>>> Can u plz provide me the solution?????????????
>>>>>> Regards,
>>>>>> Padmini.
>>>>>>> Why do you mention packages?
>>>>>>> excludedLayers is incremented because the data coordinate system is
>>>>>>> not
>>>>>>> the same as the map coodinate system.
>>>>>>> Please comment on what happend when you attempted my previous
>>>>>>> suggestions.
>>>>>>>> Hi Kenneth,
>>>>>>>> Thanks for ur suggestions.
>>>>>>>> I have created a package using OGR provider but in the buffering i
>>>>>>>> found
>>>>>>>> some problem that
>>>>>>>>      // exclude layer if:
>>>>>>>>             //  the map is non-arbitrary and the layer is arbitrary
>>>>>>>> or
>>>>>>>> vice-versa
>>>>>>>>             //     or
>>>>>>>>             //  layer and map are both arbitrary but have different
>>>>>>>> units
>>>>>>>> (arbitraryDsSrs
>>>>>>>> (dsSrsUnits != mapSrsUnits)))
>>>>>>>>                 excludedLayers++;
>>>>>>>>                 continue;
>>>>>>>> it gives difference to my data and sheboygan sample data
>>>>>>>> so that in my code  excludedLayers is incremented to 1 so i didnt
>>>>>>>> get
>>>>>>>> the
>>>>>>>> buffer features
>>>>>>>> can u plz tell me the solution?????????????????
>>>>>>>> Regards,
>>>>>>>> Padmini.
>>>>>>>>> I'm not sure that provider is case insensitive.
>>>>>>>>> Try adding the file again, but with the name "PROPERTIES.shp".
>>>>>>>>> Also, try creating a folder, and place the files in the folder.
>>>>>>>>> Then try to use the "External files" and point to the folder.
>>>>>>>>> Also try pointing directly to the file.
>>>>>>>>> When the "Test connection" is successfull, try clicking the
>>>>>>>>> rightmost button in the "coordinate system override" field, and
>>>>>>>>> it will show you what the provider returns as the coordinate
>>>>>>>>> system.
>>>>>>>>> Alternatively, try using the OGR provider instead of the SHP
>>>>>>>>> provider.
>>>>>>>>>> Hi Keneneth,
>>>>>>>>>> First of all thanks for ur patience
>>>>>>>>>> i have uploaded all the files but i didnt get the coordinate
>>>>>>>>>> system
>>>>>>>>>>     http://n2.nabble.com/file/n2676400/file.jpeg
>>>>>>>>>> again i did anything wrong??????????
>>>>>>>>>> Regards,
>>>>>>>>>> Padmini.
>>>>>>>>>>> IIRC Shape files consist of more than just the SHP file.
>>>>>>>>>>> You must upload all the "Properties.*" files to the datasource,
>>>>>>>>>>> even if the upload file dialog is misleading (you must select
>>>>>>>>>>> "All
>>>>>>>>>>> files" to see them).
>>>>>>>>>>> A ticket for this problem is here.
>>>>>>>>>>> http://trac.osgeo.org/mapguide/ticket/783
>>>>>>>>>>>> Hi,
>>>>>>>>>>>> but i did it as per ur instruction but it didn't come
>>>>>>>>>>>> http://n2.nabble.com/file/n2676097/over.jpeg
>>>>>>>>>>>> my code as same as previous
>>>>>>>>>>>>  MgResourceIdentifier featSourceId = new
>>>>>>>>>>>> MgResourceIdentifier(selLayer.GetFeatureSourceId());
>>>>>>>>>>>>             MgSpatialContextReader ctxs =
>>>>>>>>>>>> featureSrvc.GetSpatialContexts(featSourceId, false);
>>>>>>>>>>>>             String srsDefDs = "";
>>>>>>>>>>>>             if (ctxs != null && ctxs.ReadNext())
>>>>>>>>>>>>       srsDefDs = ctxs.GetCoordinateSystemWkt();
>>>>>>>>>>>> in  srsDefDs i got null
>>>>>>>>>>>> does i did any thing wrong
>>>>>>>>>>>> Regards,
>>>>>>>>>>>> Padmini.
>>>>>>>>>>>>> Yes, your FeatureSource reports an empty coordinate system, so
>>>>>>>>>>>>> you
>>>>>>>>>>>>> have
>>>>>>>>>>>>> to specify it manually.
>>>>>>>>>>>>> There is a short explanation on how to use overrides here:
>>>>>>>>>>>>> http://trac.osgeo.org/fdo/wiki/FdoGdalNotes#OverridingCoordinateSystems
>>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>>> thanks but is it necessary overriding a coordinate
>>>>>>>>>>>>>> system????????
>>>>>>>>>>>>>> How it willbe done???????
>>>>>>>>>>>>>> can u provide me some guidance???????
>>>>>>>>>>>>>> i have seen ur link but no data available in that for
>>>>>>>>>>>>>> overrides
>>>>>>>>>>>>>> coordinate
>>>>>>>>>>>>>> system
>>>>>>>>>>>>>> http://trac.osgeo.org/mapguide/wiki/maestro/UserGuides/RasterFeatureSource
>>>>>>>>>>>>>> can u plz tell me????????????
>>>>>>>>>>>>>> Regards,
>>>>>>>>>>>>>> Padmini.
>>>>>>>>>>>>>>> No, I meant "Coordinate System Override", which is located
>>>>>>>>>>>>>>> on
>>>>>>>>>>>>>>> the
>>>>>>>>>>>>>>> FeatureSource editor at the bottom.
>>>>>>>>>>>>>>> See screenshots here:
>>>>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>>>>> Thanks for ur reply
>>>>>>>>>>>>>>>> u man to say in mapdefinition(in maestro)????????????????
>>>>>>>>>>>>>>>> iam using maestro and i have selected  the coordinate
>>>>>>>>>>>>>>>> system
>>>>>>>>>>>>>>>> as
>>>>>>>>>>>>>>>> http://n2.nabble.com/file/n2675676/coor.jpeg
>>>>>>>>>>>>>>>> does i did any thing wrong???????????????
>>>>>>>>>>>>>>>> Regards,
>>>>>>>>>>>>>>>> Padmini.
>>>>>>>>>>>>>>>>> Have you tried to add a coordinate system override,
>>>>>>>>>>>>>>>>> using Maestro or Studio?
>>>>>>>>>>>>>>>>>>  Hi,
>>>>>>>>>>>>>>>>>> iam using mapguide opensource 2.0 (with .net 2.0 +IIS
>>>>>>>>>>>>>>>>>> 5.1)
>>>>>>>>>>>>>>>>>> i want to make a buffer to my data
>>>>>>>>>>>>>>>>>> the buffer function works fine for this sheboygan data
>>>>>>>>>>>>>>>>>> but
>>>>>>>>>>>>>>>>>> not
>>>>>>>>>>>>>>>>>> for
>>>>>>>>>>>>>>>>>> my
>>>>>>>>>>>>>>>>>> data
>>>>>>>>>>>>>>>>>> i have debugged the application and i got the error at
>>>>>>>>>>>>>>>>>> In Sheboygan data
>>>>>>>>>>>>>>>>>> srsDefDs comes as  GEOGCS["WGS84 Lat/Long's, Degrees,
>>>>>>>>>>>>>>>>>> -180
>>>>>>>>>>>>>>>>>> +180",DATUM["D_WGS_1984",SPHEROID["World_Geodetic_System_of_1984",6378137,298.257222932867]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]]
>>>>>>>>>>>>>>>>>> but for my data
>>>>>>>>>>>>>>>>>>   srsDefDs comes as null
>>>>>>>>>>>>>>>>>> Actually my data is in coordinate system
>>>>>>>>>>>>>>>>>> GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
>>>>>>>>>>>>>>>>>> 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]]
>>>>>>>>>>>>>>>>>> can u plz tell me the solution????????????????????????
>>>>>>>>>>>>>>>>>> plzzz
>>>>>>>>>>>>>>>>>> Regards,
>>>>>>>>>>>>>>>>>> Padmini.
>>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>>> mapguide-users mailing list
>>>>>>>>>>>>>>>>> mapguide-users at lists.osgeo.org
>>>>>>>>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/can-anyone-solved-this-buffer-problem-tp2675600p2751645.html
