[mapguide-users] select the location on map
susan Daniel daniel.susan6 at gmail.com
Mon May 4 00:08:30 EDT 2009
hi....
      *Still the same error ....*
Invalid argument(s): [1] = "javascript:Getsession()" The session ID is
invalid because the session separator character was not found.Invalid
argument(s): [1] = "javascript:Getsession()" The session ID is invalid
because the session separator character was not found. Exception occurred in
method MgUserInformation.SetMgSessionId at line 183 in file
d:\buildforgeprojects\mapguide_open_source
*my code in window.php:
<body>
<script language="javascript"type="javasript/text">
function Getsession()
 document.myform.SESSION.value=parent.parent.mapframe.GetSessionId();
function Getmapname()
 document.myform.MAPNAME.value=parent.parent.mapFrame.GetMapName() ;
</script>
<form action="selectlocation.php" method="get">
Enter PanId <input type="text" name="PanId"/><br><br>
<input type="hidden"name="SESSION" value="javascript:Getsession()"/ >
<input type="hidden"name="MAPNAME" value="javascript:Getmapname()"/  >
<input type="submit" value="Submit" />
</form>
<br><br>
Tf anyone having any idea plsss help.....I tried a lot
thanks&regards
susan
On Fri, Apr 24, 2009 at 4:24 PM, Stefan Dalakov <s.dalakov at mapware.net>wrote:
> You could use something like this (executed when window.php is loaded)
> Stefan
> susan Daniel wrote:
>> hi..all
>>       Then what i have to do?Any solution to pass these sessionId and
>> mapname ????
>> regards
>> susan
>> On Fri, Apr 24, 2009 at 3:24 PM, Stefan Dalakov <s.dalakov at mapware.net<mailto:
>> s.dalakov at mapware.net>> wrote:
>>    These javascript.functions never get executed. I checked now, I
>>    added some "alert"s  and they didn't show.
>>    susan Daniel wrote:
>>>    HI..
>>>            I removed that brace but still the error is there
>>>    regards
>>>    susan
>>>    On Fri, Apr 24, 2009 at 2:35 PM, Jackie Ng
>>>    <jumpinjackie at gmail.com <mailto:jumpinjackie at gmail.com>> wrote:
>>>        I see an extra brace (the very first one) in the javascript
>>>        block that could
>>>        be messing everything up.
>>>        - Jackie
>>>        SusanDaniel wrote:
>>>        > hi all
>>>        >         In order to display a form in the task pane i've
>>>        the following
>>>        > code
>>>        > in "....../mapviewerphp/window.php"
>>>        > <body>
>>>        > <script language="javascript">
>>>        > function getsession()
>>>        > sessionId=parent.parent.mapframe.GetSessionId();
>>>        > function getmapname()
>>>        > mapname=parent.parent.mapframe.GetMapName();
>>>        > </script>
>>>        value="javascript:getsession()"/ >
>>>        value="javascript:getmapname()"/  >
>>>        > </form>
>>>        > *and in the selectlocation .php i am having
>>>        >  </head>
>>>        >   <?php $ID= $_GET['PanId'];
>>>        >     ?>.<br />
>>>        >   <body class="AppFrame" onLoad="OnPageLoad()">
>>>        >     <h1 class="AppHeading">Select features</h1>
>>>        >     <?php
>>>        >     include '../common/common.php';
>>>        >     $args = ($_SERVER['REQUEST_METHOD'] == "POST")? $_POST:
>>>        $_GET;
>>>        >     $sessionId = $args['SESSION'];
>>>        >     $mapName = $args['MAPNAME'];
>>>        >     try
>>>        >       // Initialize the Web Extensions and connect to the
>>>        Server using
>>>        >       // the Web Extensions session identifier stored in
>>>        PHP session
>>>        > state.
>>>        >       MgInitializeWebTier ($webconfigFilePath);
>>>        >       $userInfo = new MgUserInformation($sessionId);
>>>        >       $siteConnection = new MgSiteConnection();
>>>        >       $siteConnection->Open($userInfo);
>>>        >       $map = new MgMap($siteConnection);
>>>        >       $map->Open($mapName);
>>>        >       // Get the geometry for the boundaries of District 1
>>>        >       $districtQuery = new MgFeatureQueryOptions();
>>>        >       $districtQuery->SetFilter("pan_id==$ID");
>>>        >       $layer = $map->GetLayers()->GetItem('Panchayat');
>>>        >       $featureReader = $layer->SelectFeatures($districtQuery);
>>>        >       $featureReader->ReadNext();
>>>        >       $districtGeometryData = $featureReader->
>>>        >       GetGeometry('Data');
>>>        >       // Convert the AGF binary data to MgGeometry.
>>>        >       $agfReaderWriter = new MgAgfReaderWriter();
>>>        >       $districtGeometry =
>>>        $agfReaderWriter->Read($districtGeometryData);
>>>        >       // Create a filter to select the desired features.
>>>        Combine
>>>        >       // a basic filter and a spatial filter.
>>>        >       $queryOptions = new MgFeatureQueryOptions();
>>>        >       $queryOptions->SetSpatialFilter('SHPGEOM',
>>>        $districtGeometry,
>>>        > MgFeatureSpatialOperations::Inside);
>>>        >       // Get the features from the feature source,
>>>        >       // turn it into a selection, then save the selection
>>>        as XML.
>>>        >       $layer = $map->GetLayers()->GetItem(0);
>>>        >       $featureReader = $layer->SelectFeatures($queryOptions);
>>>        >       $selection = new MgSelection($map);
>>>        >       $selection->AddFeatures($layer, $featureReader, 0);
>>>        >       $selectionXml = $selection->ToXml();
>>>        >     catch (MgException $e)
>>>        >       echo $e->GetMessage();
>>>        >       echo $e->GetDetails();
>>>        >   </body>
>>>        >     function OnPageLoad()
>>>        >       selectionXml = '<?php echo $selectionXml; ?>';
>>>        >       parent.parent.SetSelectionXML(selectionXml);
>>>        >   </script>
>>>        > </body>
>>>        > </html>
>>>        > *This code..But when i enter the panId in the form this
>>>        error is occuring
>>>        >   Invalid argument(s): [1] = "javascript:getsession()" The
>>>        session ID is
>>>        found.Invalid
>>>        > argument(s): [1] = "javascript:getsession()" The session ID
>>>        is invalid
>>>        Exception occurred
>>>        > in
>>>  d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\common\mapguidecommon\System/UserInformation.cpp
>>>        > Any mistake in my coding?????
>>>        > Help me plss
>>>        > regards
>>>        > susan
>>>        > On Wed, Apr 22, 2009 at 9:01 PM, Dave Wilson
>>>        > <dave.wilson at autodesk.com
>>>        <mailto:dave.wilson at autodesk.com>>wrote:
>>>        >>  Did you check out the samples in the downloads area of Osgeo?
>>>        >> http://mapguide.osgeo.org/download/releases/2.0.x-samples
>>>        >> Dave
>>>        >> *From:* mapguide-users-bounces at lists.osgeo.org
>>>        <mailto:mapguide-users-bounces at lists.osgeo.org> [mailto:
>>>        <mailto:mapguide-users-bounces at lists.osgeo.org>] *On Behalf
>>>        Of *Ivan Milicevic
>>>        >> *Sent:* Wednesday, April 22, 2009 1:52 AM
>>>        >> *To:* MapGuide Users Mail List
>>>        >> *Subject:* RE: [mapguide-users] select the location on map
>>>        >> You can get it from some of them. Please, read descritption.
>>>        Of *susan Daniel
>>>        >> *Sent:* Wednesday, April 22, 2009 9:46 AM
>>>        >> *Subject:* Re: [mapguide-users] select the location on map
>>>        >> Thank u....
>>>        >>                Can i get the source code of any of these
>>>        sample
>>>        >> applications? If so from where?
>>>        >> regards
>>>        >> susan
>>>        >> On Wed, Apr 22, 2009 at 1:00 PM, Ivan Milicevic <
>>>        >> Ivan.Milicevic at supranet.hr
>>>        <mailto:Ivan.Milicevic at supranet.hr>> wrote:
>>>        >> http://mapguide.osgeo.org/livegallery.html
>>>        Of *susan Daniel
>>>        >> *Sent:* Wednesday, April 22, 2009 8:06 AM
>>>        >> hi deve
>>>        >>            I couldn't find that sample application.Any link?
>>>        >> regards
>>>        >> susan
>>>        >> On Tue, Apr 21, 2009 at 8:01 PM, Dave Wilson
>>>        <dave.wilson at autodesk.com <mailto:dave.wilson at autodesk.com>>
>>>        >> wrote:
>>>        >> The sample application that does the Find Address does a
>>>        selection on the
>>>        >> map when you click on one of the search results. I thought
>>>        this was
>>>        >> discussed in the Sample Application.
>>>        >> Dave
>>>        Of *susan Daniel
>>>        >> *Sent:* Monday, April 20, 2009 12:18 AM
>>>        >> hi alll...........
>>>        >>                   I read the dev guide but didn't get any
>>>        idea regarding
>>>        >> this.Hav anyone tried this before pls give me any hint how
>>>        to start this
>>>        >> thanks &regards
>>>        >> susan
>>>        >> On Fri, Apr 17, 2009 at 8:18 PM, Dave Wilson
>>>        >> wrote:
>>>        >> Have you read through the developer’s guide? It has sample
>>>        code for
>>>        >> selection and explains many concepts. It sounds like you
>>>        need to make
>>>        >> either
>>>        >> an invoke script or invoke url call from a command in your
>>>        Basic or
>>>        >> Flexible
>>>        >> Web Layout. You don’t actually have to replace the
>>>        gettingstarted.php. In
>>>        >> the invoke script or invoke url command allows you to
>>>        specify the target
>>>        >> frame for the output of the script.
>>>        >> Regards,
>>>        >> Dave
>>>        Of *susan Daniel
>>>        >> *Sent:* Friday, April 17, 2009 3:57 AM
>>>        >> yeah...i know that..
>>>        >> On Fri, Apr 17, 2009 at 3:15 PM, Ivan Milicevic <
>>>        >> Did you know how to create file that display's database
>>>        table? If you
>>>        >> don't
>>>        >> know that you must find help somewhere else because I'm
>>>        not a PHP guy.
>>>        Of *susan Daniel
>>>        >> *Sent:* Friday, April 17, 2009 11:42 AM
>>>        >> Hi..
>>>        >>     No i dont have the file that displays database
>>>        table...Actually iam
>>>        >> doing this prjct in php.but i know javascript'
>>>        >> On Fri, Apr 17, 2009 at 3:02 PM, Ivan Milicevic <
>>>        >> Ok, so you have file that display's data from your
>>>        database table? Or you
>>>        >> don't have it at all? How familiar are you with javascript?
>>>        Of *susan Daniel
>>>        >> *Sent:* Friday, April 17, 2009 11:13 AM
>>>        >> hi...
>>>        >>    My problem is that..
>>>        >>    I have a database table..Having colums  place ,id etc .If i
>>>        >> selected(clicking) a data in the table the corresponding
>>>        place(polygon)
>>>        >> should be displayed(selected) on the map...My map is a
>>>        polygon map .each
>>>        >> polygon having unique id.and the same id is present in the
>>>        db table
>>>        >> also....Now u got it?any idea please help...
>>>        >> regards
>>>        >> susan
>>>        >> On Fri, Apr 17, 2009 at 2:24 PM, Ivan Milicevic <
>>>        >> I'm not sure that I understand your problem. With this
>>>        code you can
>>>        >> select
>>>        >> any feature on map. Can you send a little bit more
>>>        information? I'm clues
>>>        >> over there.
>>>        Of *susan Daniel
>>>        >> *Sent:* Friday, April 17, 2009 10:47 AM
>>>        >> thank you  ivan...
>>>        >>                        on which file i have to write this
>>>        coding???  any
>>>        >> idea??
>>>        >> regards
>>>        >> susan
>>>        >> On Fri, Apr 17, 2009 at 2:09 PM, Ivan Milicevic <
>>>        >> OBJEKTI is layer name and other thing is path to the
>>>        feature source.
>>>        >> "Library://SAMPLES/DATA/SEWERS/SEWERS.FeatureSource");
>>>        >> You can copy/paste feature source from mapguide maestro in
>>>        layer
>>>        >> definition
>>>        >> window.
>>>        Of *susan Daniel
>>>        >> *Sent:* Friday, April 17, 2009 9:45 AM
>>>        >> thank you Ivan
>>>        >> but  i 'd like to know on which file i want to write this
>>>        coding??
>>>        >> In ur coding OBJEKT1  is layer name right?then what is this
>>>        >> "Library://PROJEKTI/" + TIMgisUser +
>>>        "/PODACI/OBJEKTI.FeatureSource");
>>>        >> thanks and regards
>>>        >> susan
>>>        >> On Fri, Apr 17, 2009 at 12:46 PM, Ivan Milicevic <
>>>        >> Hello Susan,
>>>        >> Here is C# code for selection, it's pretty same as PHP.
>>>        >> MgSiteConnection siteConnection = null;
>>>        >>     InitializeWebTier();
>>>        >>     MgUserInformation userInfo = new
>>>        MgUserInformation(mgSessionId);
>>>        >>     siteConnection.Open(userInfo);
>>>        >>     MgResourceService resourceService =
>>>        siteConnection.CreateService(
>>>        >> MgServiceType.ResourceService) as MgResourceService;
>>>        >>     MgFeatureService featureService =
>>>        >> MgServiceType.FeatureService) as MgFeatureService;
>>>        >>     MgMap map = new MgMap();
>>>        >>     map.Open(resourceService, "1"); //opening map with
>>>        name „1“
>>>        >>     MgFeatureQueryOptions queryOptionsObjekti = new
>>>        >>     MgAgfReaderWriter geometryReaderWriter = new
>>>        >>     MgSelection selection = new MgSelection(map);
>>>        >>     //Defining layer and feature source
>>>        >>     MgLayer layerObjekti = GetLayerByName(map, "OBJEKTI");
>>>        >>     MgResourceIdentifier featureResIdObjekti = new
>>>        MgResourceIdentifier(
>>>        >>     //Creating feature filter, this is very important step!
>>>        >>     string filter = "ID=" + idO;
>>>        >>     queryOptionsObjekti.SetFilter(filter);
>>>        >>     MgFeatureReader featureReaderObjekti =
>>>        featureService.SelectFeatures(
>>>        >> featureResIdObjekti, "OBJEKTI", queryOptionsObjekti);
>>>        >>     selection.AddFeatures(layerObjekti,
>>>        featureReaderObjekti, 1);
>>>        >>     selection.Save(resourceService, "1");
>>>        >>     StringReader stream = new StringReader(selection.ToXml());
>>>        >>     string selectionXml = selection.ToXml();
>>>        >>     featureReaderObjekti.Close();
>>>        >>     map.Save();
>>>        >>     //Here, you call javascript function and pass the
>>>        selection var
>>>        >>     Response.Write("<script>select('" + selectionXml +
>>>        "');</script>");
>>>        >> //This is javascript function that set's the selection
>>>        from code and do
>>>        >> the
>>>        >> refresh.
>>>        >> function select(xml)
>>>        >> parent.mapFrame.SetSelectionXML(xml);
>>>        >> parent.mapFrame.ExecuteMapAction(10);
>>>        Of *susan Daniel
>>>        >> *Sent:* Friday, April 17, 2009 9:11 AM
>>>        >> *To:* mapguide-users at lists.osgeo.org
>>>        <mailto:mapguide-users at lists.osgeo.org>
>>>        >> *Subject:* [mapguide-users] select the location on map
>>>        >> hi all
>>>        >>         My plat form is mapguide maestro&php.I connect it
>>>        with mysql.Now
>>>        >> i
>>>        >> want to select the corresponding polygon on the map while
>>>        clicking on the
>>>        >> data in database.In order to display the database table in
>>>        the taskpane,i
>>>        >> removed the contents of the file "/mapviewerphp/getting
>>>        started .php" and
>>>        >> wrote my codings.then how to select the polygon?.Any one know
>>>        >> this????Anyone
>>>        >> having coding to do this???
>>>        >> please help me
>>>        >> thanks&regards
>>>        >>  susan
>>>        >> _______________________________________________
>>>        >> mapguide-users mailing list
>>>        >> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>        >> thanks&regards
>>>        >>  susan
>>>        >> thanks&regards
>>>        >>  susan
>>>        >> thanks&regards
>>>        >>  susan
>>>        >> thanks&regards
>>>        >>  susan
>>>        >> thanks&regards
>>>        >>  susan
>>>        >> thanks&regards
>>>        >>  susan
>>>        >> thanks&regards
>>>        >>  susan
>>>        >> thanks&regards
>>>        >>  susan
>>>        > thanks&regards
>>>        >  susan
>>>        View this message in context:
>>> http://n2.nabble.com/select-the-location-on-map-tp2649765p2691346.html
>>>        Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>    --    thanks&regards
>>>     susan
>>>    _______________________________________________ mapguide-users
>>>    mailing list mapguide-users at lists.osgeo.org
>>    mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
>> thanks&regards
>>  susan
thanks&regards
 susan
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090504/b923c946/attachment.html
