[mapguide-users] Layer creation
padmini godavarthi godavarthi.padmini at gmail.com
Sun May 10 23:50:38 EDT 2009
Hi Kenneth,
i just want to draw a line, point and polygon and want to save it in oracle
table............
Regards,
Padmini.
Kenneth Skovhede, GEOGRAF A/S wrote:
> Do you want to create lines based on points and links?
> If so, I know no good way to do it.
> The "brute force" method would be to just loop through the table
> and create the actual polylines, and insert them into a temporary storage
> (oracle table or SDF file), and then display the table as normal.
> I don't have any code to send.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> padmini godavarthi skrev:
>> Hi Kenneth,
>> can u plz tell me ur suggestion....................
>> i have a shape file and i have created this shape files into nodes and
>> links
>> tables in database
>>   Now i have a 2  tables (aaa_nodes,aaa_links) in oracle 10 g database
>> Now i want to display it in the ajax viewer (programmetically)
>> i know the way of creating packages and display it in viewer but i want
>> to
>> display it programmentically.
>> My user interface should be like this
>>  In  the check box  i want to display all the gis tables in database
>> while checking  it should display the table data (layers) on the ajax
>> viewer.........................
>> can u plz tell me the approach(actually iam confused in this situation)
>> and send me the code for this...............................
>> Regards,
>> Padmini.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/Layer-creation-tp2811326p2861128.html
