[mapguide-users] Changing Draw Order Priority of a Temporary Layer
adnanc adnan.chughtai at keynetix.com
Mon May 11 04:18:47 EDT 2009
Thank you Kenneth,
That sounds like exactly what I need.
Kind regards,
Adnan
Kenneth Skovhede, GEOGRAF A/S wrote:
> If you change the MapDefinition, the order will change for new sessions
> based on the MapDefinition.
> If you want it to change in the current session, you must change the
> draw order in the runtime map.
> I belive you can remove the layer from the runtime map layer list, and
> then re-insert it at the desired location.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> adnanc skrev:
>> Hello all,
>> I've created a temporary map layer in the session, which appears fine on
>> the
>> map, however it is added as the top most layer.  I believe this is the
>> default behaviour.
>> Any ideas as to how I can modify its draw order priority? Modify the
>> MapDefinition document?
>> Regards,
>> Adnan
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/Changing-Draw-Order-Priority-of-a-Temporary-Layer-tp2845838p2861758.html
