[mapguide-users] Selection problem with King.Oracle provider
Andreas Morf a.morf at fkl.ch
Tue May 12 10:09:19 EDT 2009
Within a project I switched from SDF provider to king.oracle (0.8.9)  and
now, selection in fusion doesn't work anymore for same data (no error, but
no highlighting nor attributes)
After investigating a little bit I found the following Selection-XML in
Query.php:
King.Oracle:
<?xml version="1.0" encoding="UTF-8"?><FeatureSet
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:noNamespaceSchemaLocation="FeatureSet-1.0.0.xsd"> <Layer
id="b3eefd0c-ffff-ffff-8000-00187186e6ed">  <Class
id="KingOra:GEORI_AV~AV_BB_GEBAEUDE~GEOMETRY">   <ID>AAAAAA==</ID>
<ID>AAAAAA==</ID>   <ID>AAAAAA==</ID>   <ID>AAAAAA==</ID>
<ID>AAAAAA==</ID>   <ID>AAAAAA==</ID>  </Class> </Layer></FeatureSet>
This, of course doesn't make lot of sense...
A primary key was set with fdo2fdo for a column named 'OID'
Any explanation for this problem?
Thanks, Andreas
