[mapguide-users] Gdal and php
Jackie Ng jumpinjackie at gmail.com
Wed May 13 00:43:58 EDT 2009
Are you talking about the GDAL provider or using the GDAL library directly in
PHP?
If you are talking about the provider, GDAL is encapsulated in the form of a
FDO provider and that is further encapsulated as MapGuide's Feature Service
API. MapGuide has no direct knowledge about GDAL.
If you want to use GDAL in this way, you have to use MapGuide's Feature
Service API.
- Jackie
djutopie wrote:
> Hi,
> I need to know the basics of the library.
> Must I specify an include path in php in
> order to use it?
> I can't perform any function from the Gdal
> library.
> How does MapGuide rules the libraries?
> Any help will be appreciated.
View this message in context: http://n2.nabble.com/Gdal-and-php-tp2869685p2879015.html
