[mapguide-users] WebServerExtensions Installation
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Wed May 13 14:00:36 EDT 2009
The steps for configuring the WebExtensions can be found here:
http://trac.osgeo.org/mapguide/wiki/MGOS2onVistaIIS7
Regards, Kenneth Skovhede, GEOGRAF A/S
Stefan Dalakov skrev:
> Thank you Jackie, I will give it a try
> Stefan Dalakov
> Jackie Ng wrote:
>> The installer is doing the following:
>> 1) Installing to C:\Program Files\MapGuideOpenSource2.0\WebServerExtensions
>> - If Apache, configures httpd.conf based on your installer preferences.
>> - If IIS, creates the virtual directories and sets up the script mappings
>> (php, aspx, jsp, fcgi) based on your installer preferences.
>> - If manual config, nothing else is done (I believe)
>> What you could do is install the web server extensions into a test machine.
>> Then grab all the files under WebServerExtensions, upload it to your remote
>> host and manually install and configure from there.
>> - Jackie
>> S.Dalakov wrote:
>>> Hi all,
>>> I want to (try to) install MGOS2.02 (WebServerExtensions) on a commercial
>>> hosting, so my question is :
>>>  Is it possible to configure WebServerExtensions manually - no provider
>>> will let me run an executable ? What in fact is the installer doing
>>> (except to copy files) ?
>>> Thank you in advance
>>> Stefan Dalakov
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090513/e07df976/attachment.html
