[mapguide-users] Exporting a MapGuide Map to HTML file?
briancomeau brian.comeau at accenture.com
Thu May 14 10:44:50 EDT 2009
So I took a look at OpenLayers, and it will not work for my particular
situation.
Any other ideas? Is there really no way to export to a standalone
self-contained map anymore?
briancomeau wrote:
> So it is possible?
> Are you saying that there isn't something like the previous MWF that I
> could simply embed into an HTML file using the OBJECT tags? If not, is
> there another way to do this? You mentioned an API, is that fairly easy to
> use?
> Thanks,
> Brian
> zspitzer wrote:
>> which of course supports mapguide , it's a client mapping api
>> On Fri, May 15, 2009 at 12:26 AM, Zac Spitzer <zac.spitzer at gmail.com>
>> wrote:
>>> 6.5 and 2009 are very different beasts
>>> by source what do you mean?
>>> you might want to have a look at openlayers
>>> z
>>> On Fri, May 15, 2009 at 12:24 AM, briancomeau
>>> <brian.comeau at accenture.com> wrote:
>>>> Hi Experts,
>>>> I have tested communication between MapGuide and JavaScript using a 6.5
>>>> version (MWF) map embedded in an HTML file. I would like to test the
>>>> same
>>>> thing with Autodesk MapGuide 2009. Is it possible to export to MWF and
>>>> use
>>>> the OBJECT tags to embed?
>>>> How else would I go about accessing the source for the generated page?
>>>> I
>>>> want to be able to communicate between Flash and the MapGuide map.
>>>> Thanks in advance!
>>>> /Brian
>>>> View this message in context:
>>>> http://n2.nabble.com/Exporting-a-MapGuide-Map-to-HTML-file--tp2891259p2891259.html
>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> Zac Spitzer -
>>> http://zacster.blogspot.com
>>> +61 405 847 168
>> Zac Spitzer -
>> +61 405 847 168
View this message in context: http://n2.nabble.com/Exporting-a-MapGuide-Map-to-HTML-file--tp2891259p2891833.html
