[mapguide-users] Mapguide Server SPecs...
Martin Morrison martin.morrison at edsi.com
Thu May 14 11:21:20 EDT 2009
Apache is single threaded...
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: Thursday, May 14, 2009 11:20 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Mapguide Server SPecs...
can you explain "primarily single threaded app" a bit more?
On Fri, May 15, 2009 at 1:12 AM, Martin Morrison
<martin.morrison at edsi.com> wrote:
> Agreed on the disk performance.  Even though Mapguide is currently a 32 bit primarily single threaded app, it's not going to stay that way forever.  Do get a server that 64-bit.  Mutli-cores and multi-processor capable.  A 32 bit app (with large address aware turned on) running on a 64-bit server will have 4 GB of ram available to it, rather than 2GB (or 3 with the switch added).  Memory is cheap, buy lot's of it.
> Do consider putting data in a SQL spatial database, this has the benefit of off-loading some of the datareads.
> If you need more help let, me know.
> Martin
> Sent: Thursday, May 14, 2009 10:33 AM
> good disk perfromance is really important, consider SSD's
> On Fri, May 15, 2009 at 12:29 AM, Scott Sonnier <ScottS at suncoastland.com> wrote:
>> What are the common specifications for a working Windows Server 2003 box to
>> run Mapguide OS?
>> Hosting will include data-Entire Counties and Aerial Photos...
>> Do I need anything special when putting this server together?
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer -
> http://zacster.blogspot.com
> +61 405 847 168
Zac Spitzer -
+61 405 847 168
