SPAM-LOW: [mapguide-users] Issue with Gdal DefaultRasterFileLocation with UNC path
Martin Morrison martin.morrison at edsi.com
Thu May 14 16:45:39 EDT 2009
My concern over this whole issue is speed.  You need your data as close and as fast as possible.  Reading raster over a network connection is not an optimal way to access the data.
Martin
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dave Wilson
Sent: Thursday, May 14, 2009 4:27 PM
To: MapGuide Users Mail List
Subject: RE: SPAM-LOW: [mapguide-users] Issue with Gdal DefaultRasterFileLocation with UNC path
Mapped drives generally don't work. Is your MapGuide server running with a login that has permissions on the network share? Running the service with the default System account will not work.
Dave
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andy Morsell
Sent: Thursday, May 14, 2009 1:34 PM
To: 'MapGuide Users Mail List'
What if you use a drive letter mapping instead of a UNC?
Andy Morsell, P.E.
Spatial Integrators, Inc.
www.SpatialGIS.com
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kori Maleski
Sent: Thursday, May 14, 2009 11:56 AM
Subject: SPAM-LOW: [mapguide-users] Issue with Gdal DefaultRasterFileLocation with UNC path
Hi all,
I am running MapGuide 2.0.2 with the service running under a domain account.
The account has full control over a file server directory containing raster imagery in Sid format.  The imagery is in LL84.
When configuring a raster data connection with the Gdal FDO I am having issues with applying coordinate system overrides when the files reside on a file server and are being accessed via UNC path.
When I reference the file locally - i.e.  c:\myfiledirectory\myfile.sid,  I can override the coordinate system with no issues in both Studio and Maestro.  Map display is perfect.
When I use a UNC path - i.e. \\myserver\myfiledirectory\myfile.sid<file:///\\myserver\myfiledirectory\myfile.sid>, and try to use the override by refreshing to see the default spatial context I get the following error:
In studio:  A popup windows error :
The exception unknown software exception (0xc0000409) occurred in the application at location 0x00ea0a66
In the event viewer:
Out of process application '/LM/W3SVC/1/ROOT/mapguide/mapagent' terminated unexpectedly.
Maestro displays no error.
But after an attempt or two in either application, the service is unresponsive and W3SVC and mgserver services have to be restarted.
Has anyone run into this issue before?
Cheers,
Kori Maleski
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090514/3dd4fcfe/attachment.html
