[mapguide-users] Teleatlas Multinet stylesheet ??
nasp nspitilli at hotmail.com
Fri May 15 08:53:16 EDT 2009
I'm new to this subject, but I think you can create a Web Mapping Service
(WMS) using OpenGis SLD.
Mapguide supports WMS, so you can indirectly integrate Teleatlas cartografy
and Mapguide.
Is that right? Is it a good solution for you?
Naspi
Ludovic Gnemmi wrote:
> Hi,
> Unfortunately not. It must be said that the work is very complex. I found
> a Teleatlas White Paper and SLD samples for GeoServer. But nothing for
> Mapguide. I really regret that Mapguide does not support OpenGis SLD.
> Such a stylesheet for MultiNet could really help the community.
> Ludovic
> nasp wrote:
>> Hi,
>> did you find a way to work with Teleatlas Multinet Database and Mapguide?
>> Regards,
>> Naspi
>>> Hi list, i have to work with Telatlas dateset to produce google like
>>> styled map.  I was wondering if someone had already worked on the
>>> rendering of layers comming fromTeleatlas Multinet Database product.  Is
>>> there any stylesheet for Mapguide? Any help would be very welcome.
>>> Ludovic
View this message in context: http://n2.nabble.com/Teleatlas-Multinet-stylesheet----tp2414470p2907589.html
