[mapguide-users] Teleatlas Multinet stylesheet ??
nasp nspitilli at hotmail.com
Fri May 15 09:11:11 EDT 2009
Thank you for your answers.
Regards,
Naspi
Ludovic Gnemmi wrote:
> Yes you are right. But i don't want to increase the number of map servers.
> There is already enough work to maintain one server :)
> nasp wrote:
>> I'm new to this subject, but I think you can create a Web Mapping Service
>> (WMS) using OpenGis SLD.
>> Mapguide supports WMS, so you can indirectly integrate Teleatlas
>> cartografy and Mapguide.
>> Is that right? Is it a good solution for you?
>> Naspi
>>> Hi,
>>> Unfortunately not. It must be said that the work is very complex. I
>>> found a Teleatlas White Paper and SLD samples for GeoServer. But nothing
>>> for Mapguide. I really regret that Mapguide does not support OpenGis
>>> SLD.
>>> Such a stylesheet for MultiNet could really help the community.
>>> Ludovic
>>> nasp wrote:
>>>> Hi,
>>>> did you find a way to work with Teleatlas Multinet Database and
>>>> Mapguide?
>>>> Regards,
>>>> Naspi
>>>>> Hi list, i have to work with Telatlas dateset to produce google like
>>>>> styled map.  I was wondering if someone had already worked on the
>>>>> rendering of layers comming fromTeleatlas Multinet Database product.
>>>>> Is there any stylesheet for Mapguide? Any help would be very welcome.
>>>>> Ludovic
View this message in context: http://n2.nabble.com/Teleatlas-Multinet-stylesheet----tp2414470p2907674.html
