[mapguide-users] help
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Tue May 19 03:04:40 EDT 2009
There is an example for MgCreateSdfParams() in the
"buffer.(php|aspx|jsp)" file in the folder
C:\program
files\MapGuideOpenSource2.0\WebServerExtensions\www\mapviewer(php|net|java)
It also shows how to set the coordinate system.
If your data has the correct projection, MapGuide will convert it to fit
the map projection.
If that does not work, you have to manually convert the items, which is
not a trivial procedure.
Regards, Kenneth Skovhede, GEOGRAF A/S
saloua wakrim skrev:
> hi! did you know lease how MgCreateSdfParams() works and what
> attributes i must give it cause ii think that the prob i have is
> coordinates i use for inserting polygone or line or point wich are not
> compatibl with map cordinates
> 2009/5/11, Kenneth Skovhede, GEOGRAF A/S <ks at geograf.dk
> <mailto:ks at geograf.dk>>:
>     Yes, that looks right.
>     You must also refresh the map (refresh/pan/zoom/etc.) in the
>     browser via javascript.
>     In addition to my other suggestions, you can also check the error
>     log for messages.
>>     hi! please i want know if this code is that what all i must do
>>     for adding new layer to map and see it in viewer frame or i must
>>     do some relation with the feature source i create in my code??
>>     thanks on advance
>>     myLayer =
>>     New MgLayer(layerDefId, resourceSrvc)
>>     myLayer.SetName(myLayerName)
>>     myLayer.SetLegendLabel(myLayerName)
>>     myLayer.SetDisplayInLegend(
>>     True)
>>     myLayer.SetSelectable(
>>     False)
>>     map.GetLayers().Insert(0, myLayer)
>>     myLayer.ForceRefresh()
>>     map.Save(resourceSrvc)
>>     2009/5/10 Kenneth Skovhede, GEOGRAF A/S <ks at geograf.dk
>>         The code looks alright.
>>         Do you refresh the map afterwards?
>>         What is in the "insertResults" ?
>>         (There can be a hidden error, due to a bug in MapGuide)
>>         Are you sure that the LayerDefinition matches the FeatureSource?
>>         Try to create the FeatureSource and LayerDefinition in
>>         "Library://" instead,
>>         so you can examine the layer from Studio/Maestro.
>>>         i try the following code for displaying layer wich contains
>>>         line in map, so i digitize a line, create temporary feature
>>>         for this line, create a layer wich contains it and add it to
>>>         the map. it doesn't give me some error but  i can see the
>>>         line in the map (i can draw it). Please help me. the code is
>>>         following:
>>>         String
>>>         dataSource = "Session:" + sessionid1 + "//" + myLayerName +
>>>         ".FeatureSource"; MgResourceIdentifier dataSourceId = new
>>>         MgResourceIdentifier(dataSource); MgFeatureService
>>>         featureSrvc =
>>>         (MgFeatureService)siteConnection.CreateService(MgServiceType.FeatureService);
>>>         if (DoesLayerExist(myLayerName, map) == false)
>>>         //create Feature Source MgClassDefinition myClassDef = new
>>>         MgClassDefinition();
>>>         myClassDef.SetName(myLayerName);
>>>         myClassDef.SetDescription(myLayerName +
>>>         " Feature Source");
>>>         myClassDef.SetDefaultGeometryPropertyName(
>>>         "SHPGEOM"); MgDataPropertyDefinition prop = new
>>>         MgDataPropertyDefinition("KEY");
>>>         prop.SetDataType(
>>>         MgPropertyType.Int32);
>>>         prop.SetAutoGeneration(
>>>         true);
>>>         prop.SetReadOnly(
>>>         true);
>>>         myClassDef.GetIdentityProperties().Add(prop);
>>>         myClassDef.GetProperties().Add(prop);
>>>         prop =
>>>         new MgDataPropertyDefinition("ID");
>>>         prop.SetDataType(
>>>         MgGeometricPropertyDefinition geomProp = new
>>>         MgGeometricPropertyDefinition("SHPGEOM");
>>>         geomProp.SetGeometryTypes(
>>>         MgFeatureGeometricType.Curve);
>>>         myClassDef.GetProperties().Add(geomProp);
>>>         MgFeatureSchema schema = new MgFeatureSchema(myLayerName +
>>>         "Schema", myLayerName + "SchemaDesc");
>>>         schema.GetClasses().Add(myClassDef);
>>>         MgCreateSdfParams sdfParams = new MgCreateSdfParams("MGA-56
>>>         (GDA94 / MGA zone 56)", map.GetMapSRS(), schema);
>>>         featureSrvc.CreateFeatureSource(dataSourceId, sdfParams);
>>>         //create layer //String layerDef = "Session:" + sessionid1 +
>>>         "//" + myLayerName + ".LayerDefinition";
>>>         MgResourceIdentifier layerDefId = new
>>>         MgResourceIdentifier("Library://essaicalque/Redline.LayerDefinition");
>>>         MgByteSource content = new MgByteSource(@"C:\Program
>>>         Files\MapGuideOpenSource\WebServerExtensions\www\essaiselect2\Layerdef.xml");
>>>         resourceSrvc.SetResource(layerDefId, content.GetReader(),
>>>         null); //code enlev‚ d'ici: ajouter layer resource … la
>>>         carte //il faut ajouter l'autre code: add layer resource to
>>>         map //DOMDocument domdoc = new DOMdocument(); MgLayer
>>>         result=add_layer_resource_to_map(layerDefId,resourceSrvc,myLayerName,myLayerName,map);
>>>         MgInsertFeatures insertFeatures = new
>>>         MgInsertFeatures(myLayerName, makeLine("1", x0, y0, x1,
>>>         y1)); MgFeatureCommandCollection commands = new
>>>         MgFeatureCommandCollection();
>>>         commands.Add(insertFeatures);
>>>         int commandIndex = commands.IndexOf(insertFeatures);
>>>         MgPropertyCollection insertResults;
>>>         insertResults = featureSrvc.UpdateFeatures(dataSourceId,
>>>         commands,
>>>         false); MgLayer myLayer1 =
>>>         map.GetLayers().GetItem(myLayerName) as MgLayer;
>>>         myLayer1.ForceRefresh();
>>>         //commands.Add(new
>>>         MgInsertFeatures(myLayerName,makeLine("1", x0, y0, x1, y1)));
>>>         map.Save(resourceSrvc);
>>>         script runat=server> Boolean result; MgPropertyCollection
>>>         makeLine(String Name, Double x0, Double y0, Double x1,
>>>         Double y1)
>>>         MgPropertyCollection PropertyCollection = new
>>>         MgPropertyCollection(); MgInt32Property nameProperty = new
>>>         MgInt32Property("ID", 1);
>>>         PropertyCollection.Add(nameProperty);
>>>         MgWktReaderWriter wktReaderWriter = new MgWktReaderWriter();
>>>         MgAgfReaderWriter agfReaderWriter = new MgAgfReaderWriter();
>>>         MgGeometry geometry = wktReaderWriter.Read("LINESTRING XY ("
>>>         + x0 + " " + y0 + "," + x1 + " " + y1 + ")") as
>>>         MgLineString; //MgGeometry geometry =
>>>         wktReaderWriter.Read("LINESTRING(3 4,10 50,20 25)") as
>>>         MgLineString; MgByteReader geometryByteReader =
>>>         agfReaderWriter.Write(geometry); MgGeometryProperty
>>>         geometryProperty = new MgGeometryProperty("SHPGEOM",
>>>         geometryByteReader);
>>>         PropertyCollection.Add(geometryProperty);
>>>         return PropertyCollection;
>>>         Boolean
>>>         DoesLayerExist(String LayerName, MgMap Map)
>>>         MgLayerCollection layers = Map.GetLayers();
>>>         result = (layers.Contains(myLayerName));
>>>         return result;
>>>         MgLayer add_layer_resource_to_map(MgResourceIdentifier
>>>         layerresourceid, MgResourceService rs, String layername,
>>>         String layerlegendlabel, MgMap map)
>>>         MgLayer myLayer = new MgLayer(layerresourceid, rs);
>>>         myLayer.SetName(layername);
>>>         myLayer.SetLegendLabel(layerlegendlabel);
>>>         true);
>>>         true);
>>>         if (!map.GetLayers().Contains(layername))
>>>         map.GetLayers().Insert(0, myLayer);
>>>         myLayer.SetVisible(
>>>         true);
>>>         myLayer.ForceRefresh();
>>>         return myLayer;
>>>         script>
>>>         _______________________________________________
>>>         mapguide-users mailing list
>>>         mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
>>>         http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090519/5fee31b0/attachment.html
