[mapguide-users] help
saloua wakrim wakrimsaloua.wakrim at gmail.com
Tue May 19 09:23:14 EDT 2009
hi! i draw polygones in layer and i want know how can i return the id of
polygone selected by user, if you have some ideas please suggest it me, i've
trough to use getselection but i don't know if it's the good method or not!!
2009/5/11 Kenneth Skovhede, GEOGRAF A/S <ks at geograf.dk>
> Yes, that looks right.
> You must also refresh the map (refresh/pan/zoom/etc.) in the browser via
> javascript.
> In addition to my other suggestions, you can also check the error log for
> messages.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> saloua wakrim skrev:
> hi! please i want know if this code is that what all i must do for adding
> new layer to map and see it in viewer frame or i must do some relation with
> the feature source i create in my code?? thanks on advance
> myLayer =
> New MgLayer(layerDefId, resourceSrvc)
> myLayer.SetName(myLayerName)
> myLayer.SetLegendLabel(myLayerName)
> myLayer.SetDisplayInLegend(
> True)
> myLayer.SetSelectable(
> False)
> map.GetLayers().Insert(0, myLayer)
> myLayer.ForceRefresh()
> map.Save(resourceSrvc)
> 2009/5/10 Kenneth Skovhede, GEOGRAF A/S <ks at geograf.dk>
>> The code looks alright.
>> Do you refresh the map afterwards?
>> What is in the "insertResults" ?
>> (There can be a hidden error, due to a bug in MapGuide)
>> Are you sure that the LayerDefinition matches the FeatureSource?
>> Try to create the FeatureSource and LayerDefinition in "Library://"
>> instead,
>> so you can examine the layer from Studio/Maestro.
>>  i try the following code for displaying layer wich contains line in map,
>> so i digitize a line, create temporary feature for this line, create a layer
>> wich contains it and add it to the map. it doesn't give me some error but  i
>> can see the line in the map (i can draw it). Please help me. the code is
>> following:
>> String
>> dataSource = "Session:" + sessionid1 + "//" + myLayerName +
>> ".FeatureSource"; MgResourceIdentifier dataSourceId = new
>> MgResourceIdentifier(dataSource); MgFeatureService featureSrvc = (
>> MgFeatureService)siteConnection.CreateService(MgServiceType.FeatureService);
>> if (DoesLayerExist(myLayerName, map) == false)
>> //create Feature Source MgClassDefinition myClassDef = new
>> MgClassDefinition();
>> myClassDef.SetName(myLayerName);
>> myClassDef.SetDescription(myLayerName +
>> " Feature Source");
>> myClassDef.SetDefaultGeometryPropertyName(
>> "SHPGEOM"); MgDataPropertyDefinition prop = new MgDataPropertyDefinition(
>> "KEY");
>> prop.SetDataType(
>> MgPropertyType.Int32);
>> prop.SetAutoGeneration(
>> true);
>> prop.SetReadOnly(
>> true);
>> myClassDef.GetIdentityProperties().Add(prop);
>> myClassDef.GetProperties().Add(prop);
>> prop =
>> new MgDataPropertyDefinition("ID");
>> prop.SetDataType(
>> MgGeometricPropertyDefinition geomProp = new
>> MgGeometricPropertyDefinition("SHPGEOM");
>> geomProp.SetGeometryTypes(
>> MgFeatureGeometricType.Curve);
>> myClassDef.GetProperties().Add(geomProp);
>> MgFeatureSchema schema = new MgFeatureSchema(myLayerName + "Schema",
>> myLayerName + "SchemaDesc");
>> schema.GetClasses().Add(myClassDef);
>> MgCreateSdfParams sdfParams = new MgCreateSdfParams("MGA-56 (GDA94 / MGA
>> zone 56)", map.GetMapSRS(), schema);
>> featureSrvc.CreateFeatureSource(dataSourceId, sdfParams);
>> //create layer //String layerDef = "Session:" + sessionid1 + "//" +
>> myLayerName + ".LayerDefinition"; MgResourceIdentifier layerDefId = new
>> MgResourceIdentifier("Library://essaicalque/Redline.LayerDefinition");
>> MgByteSource content = new MgByteSource(@"C:\Program
>> Files\MapGuideOpenSource\WebServerExtensions\www\essaiselect2\Layerdef.xml");
>> resourceSrvc.SetResource(layerDefId, content.GetReader(),
>> null); //code enlev‚ d'ici: ajouter layer resource … la carte //il faut
>> ajouter l'autre code: add layer resource to map //DOMDocument domdoc =
>> new DOMdocument(); MgLayerresult=add_layer_resource_to_map(layerDefId,resourceSrvc,myLayerName,myLayerName,map);
>> MgInsertFeatures insertFeatures = new MgInsertFeatures(myLayerName,
>> makeLine("1", x0, y0, x1, y1)); MgFeatureCommandCollection commands = new
>> MgFeatureCommandCollection();
>> commands.Add(insertFeatures);
>> int commandIndex = commands.IndexOf(insertFeatures); MgPropertyCollectioninsertResults;
>> insertResults = featureSrvc.UpdateFeatures(dataSourceId, commands,
>> false); MgLayer myLayer1 = map.GetLayers().GetItem(myLayerName) as
>> MgLayer;
>> myLayer1.ForceRefresh();
>> //commands.Add(new MgInsertFeatures(myLayerName,makeLine("1", x0, y0, x1,
>> y1)));
>> map.Save(resourceSrvc);
>> script runat=server> Boolean result; MgPropertyCollection makeLine(StringName,
>> Double x0, Double y0, Double x1, Double y1)
>> MgPropertyCollection PropertyCollection = new MgPropertyCollection();
>> MgInt32Property nameProperty = new MgInt32Property("ID", 1);
>> PropertyCollection.Add(nameProperty);
>> MgWktReaderWriter wktReaderWriter = new MgWktReaderWriter();
>> MgAgfReaderWriter agfReaderWriter = new MgAgfReaderWriter(); MgGeometrygeometry = wktReaderWriter.Read("LINESTRING
>> XY (" + x0 + " " + y0 + "," + x1 + " " + y1 + ")") as MgLineString; //MgGeometry
>> geometry = wktReaderWriter.Read("LINESTRING(3 4,10 50,20 25)") as
>> MgLineString; MgByteReader geometryByteReader =
>> agfReaderWriter.Write(geometry); MgGeometryProperty geometryProperty =
>> new MgGeometryProperty("SHPGEOM", geometryByteReader);
>> PropertyCollection.Add(geometryProperty);
>> return PropertyCollection;
>> Boolean
>> DoesLayerExist(String LayerName, MgMap Map)
>> MgLayerCollection layers = Map.GetLayers();
>> result = (layers.Contains(myLayerName));
>> return result;
>> MgLayer add_layer_resource_to_map(MgResourceIdentifier layerresourceid,
>> MgResourceService rs, String layername, String layerlegendlabel, MgMapmap)
>> MgLayer myLayer = new MgLayer(layerresourceid, rs);
>> myLayer.SetName(layername);
>> myLayer.SetLegendLabel(layerlegendlabel);
>> true);
>> true);
>> if (!map.GetLayers().Contains(layername))
>> map.GetLayers().Insert(0, myLayer);
>> myLayer.SetVisible(
>> true);
>> myLayer.ForceRefresh();
>> return myLayer;
>> script>
>> mapguide-users mailing listmapguide-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090519/c591b215/attachment.html
