[mapguide-users] Maestro Login issue
shepwaydistrictcouncil neil.thompson at shepway.gov.uk
Thu May 21 18:11:24 EDT 2009
Hi
I think you may find the port is 8008 if you did the bundled install of
MapGuide / PHP and Apache.
You can check your installation by opening the httpd.conf file located at
C:\Program Files\MapGuideOpenSource2.0\WebServerExtensions\Apache2\conf (if
you did the default install)
Open httpd.conf and look around line 235
You should have something like : ServerName localhost:8008
Hope that helps
Neil
View this message in context: http://n2.nabble.com/Maestro-Login-issue-tp2954385p2954479.html
