[mapguide-users] Tooltip on MapGuide Web API
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Mon May 25 09:35:27 EDT 2009
The operation is called "QUERYMAPFEATURES", but I can't seem
to find it as a function from the Web API.
You can see it in use if you look in the file:
C:\program
files\MapGuideOpenSource2.0\WebServerExtensions\www\viewerfiles\ajaxmappane.templ
line 2555.
You may also want to read this thread:
http://lists.osgeo.org/pipermail/mapguide-users/2007-January/004818.html
Regards, Kenneth Skovhede, GEOGRAF A/S
gatopardo skrev:
> Nobody can help me?
> gatopardo wrote:
>> How could I get the Tooltip on a point using MapGuide Web API?
>> Example:
>> I have generated an image using MgRenderingService.RenderMap, and after
>> that I want to get the tooltip on a point of this image, using the
>> coordinates on image pixels or converting them to lat-lon.
>> But I haven't found any method that makes this.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090525/9546f197/attachment.html
