[mapguide-users] Set Map Height and Width on Web Api
gatopardo luis.diosdado at dossoftware.com
Tue May 26 09:49:58 EDT 2009
When I call the methods GetDisplayHeight, GetDisplayWidth or GetDisplayScale,
all of them return 0, although before I have called
MgRenderingService.RenderMap passing the image height and width, and the
image is rendered successfully.
I don't know how to set these values, and because of this some other methods
throws an exception like "value cannot be less than or equal to zero".
Thanks for your help
View this message in context: http://n2.nabble.com/Set-Map-Height-and-Width-on-Web-Api-tp2974758p2974758.html
