[mapguide-users] Resource was not found
gatopardo luis.diosdado at dossoftware.com
Tue May 26 11:32:59 EDT 2009
Hello,
How can I create a runtime map?
I have a map instance created by MgMap.Create, but if after that I try to
call MgMap.Open or MgMap.Save, I get a exception like "Resource was not
found: Session ..... .Map"
With this instance the RenderMap works fine, and also the layers visibility
changing, but some other methods fail and I think this is the reason.
Thanks.
zspitzer wrote:
> you session has probably expired or you haven't created a runtime map
> On Mon, Mar 2, 2009 at 2:26 PM, ajid <ah_jid at yahoo.com> wrote:
>> Query on shp+dbf
>> What error of this?
>> Resource was not found:
>> Session:b1f018ee-ffff-ffff-8000-00000000b8fb_en_7F0000010AFC0AFB0AFA//ShpSample.MapResource
>> was not found:
>> Exception occurred in method MgResourceDefinitionManager.GetDocument
>> ::: PublicVisitor :::
>> www.myguidepages.com
>> View this message in context:
>> http://n2.nabble.com/Resource-was-not-found-tp2407369p2407369.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer -
> http://zacster.blogspot.com
> +61 405 847 168
View this message in context: http://n2.nabble.com/Resource-was-not-found-tp2407369p2975416.html
