[mapguide-users] prob with GetSelectionXml()
wakrimsaloua.wakrim at gmail.com wakrimsaloua.wakrim at gmail.com
Thu May 28 05:49:23 EDT 2009
hi all! did you know what does" id" in <layer id=255.....> returned by selection xml mean? cause when i got the XmlSelection from map and i use it for getting layers it contains i've error wich say that layers is nothing but the selection is nt i've verifyed it the selection i got from map is not empty but the layers are nothing, so i think that can be caused by the "id" in <layer id=255.....> returned by the selection if that mean the session for example cause me when i create layer i do it with "library://......mapdefinition" and not "Session//....mapdefinition" so i think that if the id on <layer id=255.....> means the session used by user i think that layer contained on selection won't be known, but i'm not sure please if you have some idea tell it me, thanks a lot on advance.
