[mapguide-users] Add Data Connection for Shp's Problem
Tom Lazo tom.lazo at hotmail.com
Thu May 28 10:55:00 EDT 2009
Thanks, i'll try to do it as you said. But, if it doesn't work, could you
tell me how could i do it manually, is there any tutorial for that?.
Thanks again
Tom
Kenneth Skovhede, GEOGRAF A/S wrote:
> You need to upload more than just the .shp file.
> There are usually a bunch of files related to a single shape file,
> and you need to upload them all (they all have the same filename, but
> different extensions).
> The Maestro UI was not really helpfull there, so I changed it.
> You can either use your current version of Maestro, and add the files
> manually,
> or use the newest preview version and it will ask you if you want it
> done automatically.
> (new version released a few hours ago r3911):
> http://trac.osgeo.org/mapguide/wiki/maestro/Downloads
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Tom Lazo skrev:
>> Hi all,
>> Well, i've tried to "Upload Data into a new Feature Source" via mapguide,
>> but the link throws me to a "Not found" page. Ok... i've realized this
>> problems some weeks before.. so i got the AutoDesk MapGuide Studio
>> 2009...trial.. ok. Actually this frameworks allows me to upload the data
>> from a shape file.
>> Ok, now i'm trying to do the same but with Maestro, so i go to
>> file->new->Data Connection->OSGeo FDO Provider for SHP... then i search
>> my
>> shape file and open it.
>> Now, i validate this resource whith the big green check and i get this
>> error:
>> Validating file:
>> Session:08df1c68-2d35-102c-8000-001cc0a62e16_es_7F0000010AFC0AFB0AFA//6d899f62-7b06-4fb3-8f53-d8e9b2187049.FeatureSource
>> Error - OSGeo.MapGuide.MaestroAPI.FeatureSource: Failed to read schema
>> description: Error en el servidor remoto: (559)
>> MgInvalidStreamHeaderException.:
>> Invalid stream header exception.
>> Exception occurred in method MgCommand.GetResponse at line 152 in file
>> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\common\mapguidecommon\Services/Command.cpp
>> Plz, tell what's the cause of this mistake...i'm really lost.
>> Thanks
>> Tom
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/Add-Data-Connection-for-Shp%27s-Problem-tp2984081p2988134.html
