[mapguide-users] WMS layers
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Sun May 31 06:21:51 EDT 2009
Sometimes the initial display extents are invalid when previewing the item.
This is especially true for raster based data.
Try creating a map with the correct extents and the correct coordinate
system.
Then add the layer and preview the map.
If it does not work, try adding a coordinate system override for the
data source.
You should also check the servers error.log file for hints.
Regards, Kenneth Skovhede, GEOGRAF A/S
pedrongvenancio at yahoo.com skrev:
> Hello!
> Start by giving the congratulations for this new release 2.1!
> I have some questions ...
> 1. I would add WMS layers. The procedure that was tried with the
> Maestro, through FDO WMS. I put the server
> http://mapas.igeo.pt/wms/mdt50m and left the default image height
> blank. Create a layer but then, when I do the preview, is not showing
> anything ... I am doing something wrong?
> 2. When Samples for Release 2.1?
> Thank you very much!
> Regards,
> Pedro Venancio
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090531/b6957c3a/attachment.html
