[mapguide-users] mapguide trouble installing ubuntu
UV uvwild at googlemail.com
Mon Nov 2 10:07:20 EST 2009
in the beginning of this year I have build mapguide 2.0.2 on Centos5 and
collected my steps on
http://wiki.osgeo.org/wiki/Building_MapGuide_on_CentOS_5
I think the build on RHEL3 was also working fine...
there are other guides for other unixes also
<http://wiki.osgeo.org/wiki/Building_MapGuide_quick_starts_guides>
open a bash shell as root (su) and try again.
the sudo seems a bit limited for a complete build
Remco Houtkamp wrote:
> Hi, after a lot of trouble with windows, fdo and postgis I'm trying a setup with ubuntu. I just don't know that much about linux so I'm just following the how-to' s.
> After I enter the sudo ./build_oem.sh command  I see a lot text within terminal (installing?) but it stops at a certain point and gives me the following error (some of it is dutch):
> config.status: error: cannot find input file: `Makefile.in'
> make: *** Geen doelen opgegeven en geen makefile gevonden.  Gestopt.
> DWFCORE 1.0: Error build failed (0).................
> remco at ubuntu:/usr/local/mapguideopensource$ gcc
> gcc: no input files
> remco at ubuntu:/usr/local/mapguideopensource$ aclocal
> configure.in:18: warning: macro `AM_PROG_LIBTOOL' not found in library
> autom4te: cannot create autom4te.cache: Bestand of map bestaat niet
> aclocal: autom4te failed with exit status: 1
> remco at ubuntu:/usr/local/mapguideopensource$ sudo ./build_oem.sh
> MapGuide Open Source build script for OEM components
> OEM Build Initialization ............................
> Oem Libraries will be installed at: /usr/local/mapguideopensource
> ./build_oem.sh: 595: pushd: not found
> ace: Initialization...........................
> ace: Configure/Build ...........................
> ./build_oem.sh: 610: pushd: not found
> ACE 5.4: Error build failed (0).................
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091102/e470a4f6/attachment.html
