[mapguide-users] Simple .NET Function Hello World!
Rock Beans rockbeans at gmail.com
Tue Nov 3 10:43:23 EST 2009
That worked thanks! Here is a great exanple to help others that are
not using the viewer which must do this for you.
public string DoMapGuide()
	string mapName = "Sheboygan";
	string resourceLocation =
"Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition";
	string webConfig = "C:\\Program Files
(x86)\\OSGeo\\MapGuide\\Web\\www\\webconfig.ini";
	string userName = "Anonymous";
	string userPassword = "";
	MapGuideApi.MgInitializeWebTier(webConfig);
	MgUserInformation userInfo = new MgUserInformation(userName, userPassword);
	MgSite site = new MgSite();
	site.Open(userInfo);
	String mgSessionId = site.CreateSession();
	MgUserInformation userInfoSession = new MgUserInformation(mgSessionId);
	MgSiteConnection siteConnection = new MgSiteConnection();
	siteConnection.Open(userInfoSession);
	MgResourceIdentifier resourceId = new MgResourceIdentifier(resourceLocation);
	//create resource services
	MgResourceService resourceSrvc =
(MgResourceService)siteConnection.CreateService(MgServiceType.ResourceService);
	MgMap map = new MgMap();
	map.Create(resourceSrvc, resourceId, mapName);
	return mgSessionId;
On Tue, Nov 3, 2009 at 2:19 AM, Kenneth Skovhede, GEOGRAF A/S
<ks at geograf.dk> wrote:
> That is an odd issue.
> What happens is that you create a runtime map (MgMap.Create).
> Internally that means that the MapDefinition xml is converted to a binary
> format, known as a "runtime map".
> For some reason, you cannot pass the resource id for the runtime map to the
> MgMap.Open or MgMap.Create call,
> but must pass the map name. The method overload you are calling is not
> documented (afaik).
> Instead, try calling:
> map.Create(resourceSrvc, resourceId, "Sheboygan");
> The calls are documented here:
> http://mapguide.osgeo.net/files/mapguide/docs/webapi/da/df8/class_mg_map_ef5b2026a831d04c93a60b7ba2460082.html
> http://mapguide.osgeo.net/files/mapguide/docs/webapi/da/df8/class_mg_map_50515a38c44c727f7caa214138cd075b.html#50515a38c44c727f7caa214138cd075b
> Be aware that the MapGuide viewer will not use a pre-created runtime map,
> but always create (and overwrite) a runtime map.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Rock Beans skrev:
>> I create a session then use session to create site connection. I then
>> have issues with map.open(). I tried map name "Sheboygan" and I tried
>> using a resource indentifier. What am I doing wrong?
>> MapGuideApi.MgInitializeWebTier("C:\\Program Files
>> (x86)\\OSGeo\\MapGuide\\Web\\www\\webconfig.ini");
>> MgUserInformation userInfo = new MgUserInformation("Anonymous", "");
>> //MgResourceIdentifier resourceId = new
>> MgResourceIdentifier("Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition");
>> map.Create(resourceId, mapName);
>> map.Open(resourceSrvc, mapName)y
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
