[mapguide-users] Creating and adding layers
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Wed Nov 4 02:39:51 EST 2009
There is a short (incomplete) guide here that explains the procedure
from a users viewpoint:
http://trac.osgeo.org/mapguide/wiki/maestro/UserGuide
If you have MapGuide Enterprise, you can get Studio for free, which has
a manual in the "Help" menu.
If you need to create data as well, you need a GIS client application,
such as Autocad Map, ArcGIS or MapInfo.
(There are free clients avalible as well)
Your question is a bit vague, so if this is an answer to another
question, can you explain your current setup?
Regards, Kenneth Skovhede, GEOGRAF A/S
oshan skrev:
> Hi
> I want to know how to create layers?
> Say that you have a map and you want to create layers for political
> divisions. How would you go about doing this?
> I ask this before but I didn't get any answer. My apologies if its a stupic
> question! Since I don't really have any good vectored based maps, is it
> possible to use a jpeg as a base image? How do I achieve this?
> I appreciate any help
> Thanks
