[mapguide-users] Creating and adding layers
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Wed Nov 4 03:16:41 EST 2009
Yes, it is possible.
You need a "runtime map" instance.
Short C# example:
MgResourceService srvc;
MgMap map = new MgMap();
map.Open(srvc, "mapname");
MgLayer layer = new MgLayer();
... set layer properties, such as .LayerDefinition path ...
map.Layers.Add(layer);
map.Save(srvc, "mapname");
Regards, Kenneth Skovhede, GEOGRAF A/S
Dejan Gregor skrev:
> Hi,
> I would like to add a question -- is it possible to programmatically
> add new layers into the 'map' triggering a command from the MapGuide
> web client?
> It is an actual configuration change of the 'map' that is not done in
> Mapguide Mestro.
> Dejan
> On Wed, Nov 4, 2009 at 08:39, Kenneth Skovhede, GEOGRAF A/S
> <ks at geograf.dk <mailto:ks at geograf.dk>> wrote:
>     There is a short (incomplete) guide here that explains the
>     procedure from a users viewpoint:
>     http://trac.osgeo.org/mapguide/wiki/maestro/UserGuide
>     If you have MapGuide Enterprise, you can get Studio for free,
>     which has a manual in the "Help" menu.
>     If you need to create data as well, you need a GIS client
>     application, such as Autocad Map, ArcGIS or MapInfo.
>     (There are free clients avalible as well)
>     Your question is a bit vague, so if this is an answer to another
>     question, can you explain your current setup?
>     oshan skrev:
>         Hi
>         I want to know how to create layers?
>         Say that you have a map and you want to create layers for
>         political
>         divisions. How would you go about doing this?
>         I ask this before but I didn't get any answer. My apologies if
>         its a stupic
>         question! Since I don't really have any good vectored based
>         maps, is it
>         possible to use a jpeg as a base image? How do I achieve this?
>         I appreciate any help
>         Thanks
>     _______________________________________________
>     mapguide-users mailing list
>     mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091104/18e135ff/attachment.html
