[mapguide-users] Add geometry to SHP
Simon Pelicon simon at sl-king.com
Fri Nov 6 02:55:36 EST 2009
Hi!
Here is sample in C# from my code using just  FDO .NET API.
This inserts FEATURE in any FDO datasource specified in my FDO connection
(m_Conn) like SHP,SDF, oracle ....
IInsert command =
(IInsert)m_base.m_Conn.CreateCommand(CommandType.CommandType_Insert);
FgfGeometryFactory factory = new FgfGeometryFactory();
IDirectPosition position = factory.CreatePositionXYZ(X,Y, 0.0);
IPoint point = factory.CreatePoint(position);
command .PropertyValues.Add(new PropertyValue(GEOMETRY_COLUMN, new
GeometryValue(factory.GetFgf(point))));
command .PropertyValues.Add(new PropertyValue(LAYER_COLUMN, new
StringValue(bref.Layer)));
command .PropertyValues.Add(new PropertyValue(BLOCK_COLUMN, new
StringValue(bref.Name)));
reader = command.Execute();
if (reader.ReadNext())
Simon
On Fri, Nov 6, 2009 at 8:27 AM, Dejan Gregor <dejan.gregor at gmail.com> wrote:
> Dear Fabio,
> you are saying that with the exsiting FDO it is possible to add geometry to
> a SHP?
> Do you have a sample code for MGOS 2.x also for the interface or maybe a
> whole project/sln? I am not a programmer, but would like just to test this
> functionality in MapGuide.
> Best regards,
> Dejan
> On Fri, Nov 6, 2009 at 00:29, Zac Spitzer <zac.spitzer at gmail.com> wrote:
>> what's in the string? it's probably an error string
>> if your feature source readonly?
>> http://trac.osgeo.org/mapguide/ticket/649
>> a very nasty annoying bug
>> z
>> On Fri, Nov 6, 2009 at 9:45 AM, Jackie Ng <jumpinjackie at gmail.com> wrote:
>> > What does your ReleaseReader() look like?
>> > If it's from the samples, it's supposed to close any open
>> MgFeatureReaders
>> > that may exist in the result returned from
>> MgFeatureService.UpdateFeatures()
>> > - Jackie
>> > sekko970 wrote:
>> >> I tryng to add a point to an existing SHP data connection in ASP.Net
>> >> application, using MG API.
>> >> Dim dataSource as String = "Library://.../MySHP.FeatureSource"
>> >> Dim dataSourceId As New MgResourceIdentifier(dataSource)
>> >> Dim MyProps As New MgPropertyCollection()
>> >> Dim agfRW As New MgAgfReaderWriter()
>> >> Dim geomFactory As New MgGeometryFactory
>> >> Dim myPoint As MgPoint =
>> >> geomFactory.CreatePoint(geomFactory.CreateCoordinateXY(X, Y))
>> >> 'ID
>> >> Dim IDProp As New MgInt32Property("FeatID", IDValue)
>> >> MyProps.Add(IDProp)
>> >> 'MyProp
>> >> Dim MyProp As New MgDoubleProperty("MyProp", MyPropValue)
>> >> MyProps.Add(MyProp)
>> >> 'Geometry
>> >> Dim geomReader As MgByteReader = agfRW.Write(myPoint)
>> >> Dim geometryProp As New MgGeometryProperty("Geometry", geomReader)
>> >> MyProps.Add(geometryProp)
>> >> Dim propCollection As New MgBatchPropertyCollection()
>> >> propCollection.Add(MyProps)
>> >> Dim commands As New MgFeatureCommandCollection()
>> >> commands.Add(New MgInsertFeatures(MyFeatureName, propCollection))
>> >> Dim res As MgPropertyCollection =
>> featureSrvc.UpdateFeatures(dataSourceId,
>> >> commands, False)
>> >> ReleaseReader(res, commands)
>> >> In ReleaseReader, I have the following error:
>> >> Unable to cast object of type 'OSGeo.MapGuide.MgStringProperty' to type
>> >> 'OSGeo.MapGuide.MgFeatureProperty'.
>> >> In fact, res has only one property of type MgStringProperty: but why?
>> >> Have you any idea where is the error?
>> >> Thanks, Fabio
>> > View this message in context:
>> http://n2.nabble.com/Add-geometry-to-SHP-tp3953583p3955574.html
>> > Sent from the MapGuide Users mailing list archive at Nabble.com.
>> > _______________________________________________
>> > mapguide-users mailing list
>> > mapguide-users at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> Zac Spitzer
>> Solution Architect / Director
>> Ennoble Consultancy Australia
>> http://www.ennoble.com.au
>> http://zacster.blogspot.com
>> +61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091106/3b3c4792/attachment.html
