[mapguide-users] Add geometry to SHP
sekko970 fabio.franceschini at techneteam.it
Fri Nov 6 11:57:03 EST 2009
Hi Simon,
I have solved the problem.
After your valuable help to add feature to SHP file using FDO API, I ask you
to help me again :-)
I need to create the shape file programmatically: have you an example to
make it using FDO API?
Thanks a lot,
F.
sekko970 wrote:
> The problem is that I cannot include FDOSpatial.dll in my project.
> In fact, if I try to create a reference to OSGeo.FDO.Spatial.dll, I have
> the
> following error:
> no type libraries were found in the component
> (FDOSpatial.dll is already in my project bin folder).
> f.
> sekko970 wrote:
>> I have already downloaded all the dll for FDO Windows SDK, but 3.4
>> version.
>> f.
>> Simon Pelicon wrote:
>>> You have all this files (also  OSGeo.FDO.Spatial.dll ) in FDO Windows
>>> SDK.
>>> download link:
>>> http://fdo.osgeo.org/content/fdo-331-downloads
>>> <http://fdo.osgeo.org/content/fdo-331-downloads>simon
>>> On Fri, Nov 6, 2009 at 10:58 AM, sekko970
>>> <fabio.franceschini at techneteam.it>wrote:
>>>> Ok for
>>>> OSGeo.FDO.dll
>>>> OSGeo.FDO.Geometry.dll
>>>> OSGeo.FDO.Common.dll
>>>> but if I try to create a reference to OSGeo.FDO.Spatial.dll, I have the
>>>> following error:
>>>> no type libraries were found in the component.
>>>> f.
>>>> > Hi!
>>>> > Add references to this files:
>>>> > OSGeo.FDO.dll
>>>> > simon
>>>> > On Fri, Nov 6, 2009 at 9:41 AM, sekko970
>>>> >> Hi Simon,
>>>> >> what I have to do to include in my ASP.NET project FDO .NET API?
>>>> >> > Hi!
>>>> >> > Here is sample in C# from my code using just  FDO .NET API.
>>>> >> > This inserts FEATURE in any FDO datasource specified in my FDO
>>>> >> connection
>>>> >> > (m_Conn) like SHP,SDF, oracle ....
>>>> >> > IInsert command =
>>>> (IInsert)m_base.m_Conn.CreateCommand(CommandType.CommandType_Insert);
>>>> >> > FgfGeometryFactory factory = new FgfGeometryFactory();
>>>> >> > IDirectPosition position = factory.CreatePositionXYZ(X,Y, 0.0);
>>>> >> > IPoint point = factory.CreatePoint(position);
>>>> >> > command .PropertyValues.Add(new PropertyValue(GEOMETRY_COLUMN, new
>>>> >> > GeometryValue(factory.GetFgf(point))));
>>>> >> > command .PropertyValues.Add(new PropertyValue(LAYER_COLUMN, new
>>>> >> > StringValue(bref.Layer)));
>>>> >> > command .PropertyValues.Add(new PropertyValue(BLOCK_COLUMN, new
>>>> >> > StringValue(bref.Name)));
>>>> >> > reader = command.Execute();
>>>> >> > if (reader.ReadNext())
>>>> >> > Simon
>>>> >> > On Fri, Nov 6, 2009 at 8:27 AM, Dejan Gregor
>>>> <dejan.gregor at gmail.com>
>>>> >> > wrote:
>>>> >> >> Dear Fabio,
>>>> >> >> you are saying that with the exsiting FDO it is possible to add
>>>> >> geometry
>>>> >> >> to
>>>> >> >> a SHP?
>>>> >> >> Do you have a sample code for MGOS 2.x also for the interface or
>>>> maybe
>>>> >> a
>>>> >> >> whole project/sln? I am not a programmer, but would like just to
>>>> test
>>>> >> >> this
>>>> >> >> functionality in MapGuide.
>>>> >> >> Best regards,
>>>> >> >> Dejan
>>>> >> >> On Fri, Nov 6, 2009 at 00:29, Zac Spitzer <zac.spitzer at gmail.com>
>>>> >> wrote:
>>>> >> >>> what's in the string? it's probably an error string
>>>> >> >>> if your feature source readonly?
>>>> >> >>> http://trac.osgeo.org/mapguide/ticket/649
>>>> >> >>> a very nasty annoying bug
>>>> >> >>> z
>>>> >> >>> On Fri, Nov 6, 2009 at 9:45 AM, Jackie Ng
>>>> <jumpinjackie at gmail.com>
>>>> >> >>> wrote:
>>>> >> >>> > What does your ReleaseReader() look like?
>>>> >> >>> > If it's from the samples, it's supposed to close any open
>>>> >> >>> MgFeatureReaders
>>>> >> >>> > that may exist in the result returned from
>>>> >> >>> MgFeatureService.UpdateFeatures()
>>>> >> >>> > - Jackie
>>>> >> >>> > sekko970 wrote:
>>>> >> >>> >> I tryng to add a point to an existing SHP data connection in
>>>> >> ASP.Net
>>>> >> >>> >> application, using MG API.
>>>> >> >>> >> Dim dataSource as String =
>>>> "Library://.../MySHP.FeatureSource"
>>>> >> >>> >> Dim dataSourceId As New MgResourceIdentifier(dataSource)
>>>> >> >>> >> Dim MyProps As New MgPropertyCollection()
>>>> >> >>> >> Dim agfRW As New MgAgfReaderWriter()
>>>> >> >>> >> Dim geomFactory As New MgGeometryFactory
>>>> >> >>> >> Dim myPoint As MgPoint =
>>>> >> >>> >> geomFactory.CreatePoint(geomFactory.CreateCoordinateXY(X, Y))
>>>> >> >>> >> 'ID
>>>> >> >>> >> Dim IDProp As New MgInt32Property("FeatID", IDValue)
>>>> >> >>> >> MyProps.Add(IDProp)
>>>> >> >>> >> 'MyProp
>>>> >> >>> >> Dim MyProp As New MgDoubleProperty("MyProp", MyPropValue)
>>>> >> >>> >> MyProps.Add(MyProp)
>>>> >> >>> >> 'Geometry
>>>> >> >>> >> Dim geomReader As MgByteReader = agfRW.Write(myPoint)
>>>> >> >>> >> Dim geometryProp As New MgGeometryProperty("Geometry",
>>>> geomReader)
>>>> >> >>> >> MyProps.Add(geometryProp)
>>>> >> >>> >> Dim propCollection As New MgBatchPropertyCollection()
>>>> >> >>> >> propCollection.Add(MyProps)
>>>> >> >>> >> Dim commands As New MgFeatureCommandCollection()
>>>> >> >>> >> commands.Add(New MgInsertFeatures(MyFeatureName,
>>>> propCollection))
>>>> >> >>> >> Dim res As MgPropertyCollection =
>>>> >> >>> featureSrvc.UpdateFeatures(dataSourceId,
>>>> >> >>> >> commands, False)
>>>> >> >>> >> ReleaseReader(res, commands)
>>>> >> >>> >> In ReleaseReader, I have the following error:
>>>> >> >>> >> Unable to cast object of type
>>>> 'OSGeo.MapGuide.MgStringProperty'
>>>> to
>>>> >> >>> type
>>>> >> >>> >> 'OSGeo.MapGuide.MgFeatureProperty'.
>>>> >> >>> >> In fact, res has only one property of type MgStringProperty:
>>>> but
>>>> >> why?
>>>> >> >>> >> Have you any idea where is the error?
>>>> >> >>> >> Thanks, Fabio
>>>> >> >>> > View this message in context:
>>>> >> >>> http://n2.nabble.com/Add-geometry-to-SHP-tp3953583p3955574.html
>>>> >> >>> > Sent from the MapGuide Users mailing list archive at
>>>> Nabble.com.
>>>> >> >>> > _______________________________________________
>>>> >> >>> > mapguide-users mailing list
>>>> >> >>> > mapguide-users at lists.osgeo.org
>>>> >> >>> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>> >> >>> Zac Spitzer
>>>> >> >>> Solution Architect / Director
>>>> >> >>> Ennoble Consultancy Australia
>>>> >> >>> http://www.ennoble.com.au
>>>> >> >>> http://zacster.blogspot.com
>>>> >> >>> +61 405 847 168
>>>> >> http://n2.nabble.com/Add-geometry-to-SHP-tp3953583p3957522.html
>>>> >> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>> http://n2.nabble.com/Add-geometry-to-SHP-tp3953583p3957821.html
View this message in context: http://n2.nabble.com/Add-geometry-to-SHP-tp3953583p3959951.html
