[mapguide-users] Hot to set MgProperty to NULL
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Tue Nov 10 04:05:24 EST 2009
Yes, that seems way to do it seems like a workaround for another problem.
Regards, Kenneth Skovhede, GEOGRAF A/S
Gunter Becker skrev:
> Thanks Kenneth.
> I've found that SetNull() works for SQL Server 2008 Provider.
> But it's very odd to first initialize a "default" value (in my case I use
> Int16.MinValue)  and then set the whole MgProperty-Object to NULL. Why not
> have a constructor that allows NULL values?
> Thanks again, Gunter
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> SetNull() is the method to use.
>> I've found that various providers either break on, or ignore, null values.
>>> Hi,
>>> I'd like to update existing features with NULL values.
>>> Let's say I have a property called 'age' and I want to delete the value
>>> of
>>> this property
>>> so that I have a null value instead of the integer value.
>>> The only contructor I've found needs two parameters. The property name
>>> and
>>> the property value.
>>> The property value can't be null:
>>> MgInt16Property newProperty =  new MgInt16Property(propertyName,
>>> Convert.ToInt16(propertyValue));
>>> There is a SetNull-Methode which I can set to 'true' afterwards. But this
>>> doesn't affect anything.
>>> Any idea on how to update a property with a null value???
>>> Thanks Gunter
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091110/c0c87373/attachment.html
