[mapguide-users] problem with the formFrame.Submit method
Mauricio Villablanca mgvillablanca at yahoo.com
Tue Nov 10 23:23:54 EST 2009
Well duh, you are reloading the same page. Assuming your script is dynamic
and will output data based on the parameters it receives, did you write the
code to process the parameters you are sending?
ram282 wrote:
> I have a problem with the formFrame.Submit method. When I mention the page
> url in this method the page is popping up.
> suppose
> formFrame.Submit("../Development/Default.aspx",params,null)
> current active page is Default.aspx page
>  when I execute the above code I don't want to get another same page. The
> result should be shown in the same window. Please give me any idea
> Regards,
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/problem-with-the-formFrame-Submit-method-tp3754698p3984394.html
